Quote: Someone tested various speed SD cards and reading the cards via USB 3.0. Turns out it's running at USB 2.0 speeds
Well, that was always doomed to fall in to the circular file marked "Fail".
Class 10 SD cards only need to read and write at a sustained 10 Mbytes/sec
USB2 supports a maximum data rate of 480mBits/sec, which is 60 Mbytes/sec
USB3 supports a maximum data rate of 5gBits/sec, which is 625 Mbytes/sec
When the SD cards are running slower then the speed of the USB, you cannot use it to evaluate the USB.
Even a UHS-1 SD card only has to run at 50Mbytes/sec, still slower then USB2.
Unless you can hook up an external SSD or HDD and record directly to it, and are able to run Burst Mode still with no slow down after the usual number of frames, you will have no accurate data as to whether the USB3 port is running at the full USB3 speed.
Originally posted by kadajawi
but I doubt that the h264 is encoded in software on a generic CPU.
As I understand the process (and I'm not 100% on it, only done light reading on it), CPU isn't the right term,.. The firmware is flashed in to a NAND based chip, and builds the processor in the NAND, rather then it being a CPU that is etched in to Silicon wafers on a production line.
So when you upload fresh firmware, you're rearranging the NAND to effectively be a new processor with different wiring.
So the processing of commands in done in a hardware layer, not just by new software.
Now, if it was an Atom or i7 or the like, then there is hardware in the CPU that does the compression work.
Regardless of which type of Chip is used, it should still be fast enough to write out full dynamic range Cinema DNG files.
pTom: what does it show on a HDMI screen?
Given my personal experience with an Intensity Shuttle, I'm not that confident that the Pro PCIe card would work any better.
And was that test done with the Class10 '45Mb' Extreme, or the UHS1 version?
I've got the class10 sort and the speeds I get from USB2 external card reader, vs the one built in to my laptop, vary by as much as 20Mb/s
