10-08-2013, 03:59 PM   #16
twitch's Avatar
Here is another representation, from Pentax this time. Once you understand an AF "point" looks for contrast at any point along the vertical and horizonal lines of the active AF point then you can see the problem.
10-08-2013, 04:11 PM   #17
QuoteOriginally posted by kenyee Quote
the current AF points are huge and don't match the display in the viewfinder.
Most of us know how big they are - they aren't that misplaced in case of my bodies, but yes the size is correct.
Someone a while back who had a lot of Pentax f/1.4 lenses said the AF system just wasn't accurate enough (he was a practicing pro who did a lot of narrow DOF natural light stuff, not Benjikan's studio stuff)....you couldn't lay the focus point on an eye in a portrait and expect focus exactly at that point...it'd be FF/BF a bit instead. That pro switched over to Nikon and was a lot happier.
Focus precision with fast lenses has more to do with wider spaced pair of focus sensors than the size of the "point" itself. Pentax had f/5.6 sensors only (till SAFOX X), so it couldn't be really accurate here and to my understanding the longer f/5.6 sensors are, the more precise the AF system is.
So it really depends on what you shoot and what lenses you have.
I use fast primes most of the time and yes I do quite a lot of shallow DOF stuff too.
10-09-2013, 09:00 AM   #18
bwDraco's Avatar
The AF sensor has nine vertical lines indicating nine columns of AF points, but only 7 columns of AF points actually exist. Could the two points outside the 5x5 grid be double-wide?
--DragonLord
af, dslr, k-3, k3, pentax k-3
Why Pentax lenses are smaller than ones from Nikon or Canon? kitestring Pentax SLR Lens Discussion 32 09-13-2013 12:54 PM
Religious Sites are Worst for Malware boriscleto General Talk 4 05-01-2012 04:07 PM
What are good buying sites...apart from Ebay? pickles Film SLRs and Compact Film Cameras 14 05-08-2011 04:38 AM
Are SOFT FOCUS lenses actually useful? PentaxForums-User Pentax SLR Lens Discussion 45 01-01-2010 08:36 AM
Which DA lenses are actually full frame capable? Noisychip Pentax SLR Lens Discussion 18 05-02-2008 08:42 AM
All times are GMT -7. The time now is 11:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
