10-08-2013, 01:42 PM   #1
Sagitta's Avatar
Will the K-3 automagically kill purple fringing and the like?
Probably reading way more into the ability of the camera than is actually there, but from the description over on B&H's site, it describes the sensor as: (bolding what jumped at me)
Utilizing an anti-aliasing simulator that applies microscopic vibrations at the subpixel level, moiré and other color digital artifacts will not register on the sensor and therefore will not appear in the final image.
Does this mean that the sensor is immune or at least somewhat resistant to stuff like purple fringing? What other 'color digital artifacts' would they be talking about other than moire?
As someone who loves his cheap old manual lenses, if this camera can help kill fringing, I'm probably hooked like a trout here on upgrading come tax season.
10-08-2013, 02:16 PM   #2
Cynog Ap Brychan's Avatar
I shouldn't think it would make much difference. The colour artefacts referred to here are those associated with fine, repetitive patterns and are associated with the Bayer filter overlaid on the sensor. Purple fringing is caused mainly by aberrations in lenses not optimised for digital sensors (i.e., film). It is, however, relatively easy to remove in post-processing, or so I am given to understand. I'm no expert on optic or lenses, but I believe my answer to be reasonably accurate. If not, there are others much more knowledgeable than I on this forum who will soon correct any errors.
10-08-2013, 03:19 PM   #3
I'm not an expert here either, but I'd have to say nope, definitely not purple fringing. Maybe they are referring to false color, which is related to moire. Moire is a phenomenon which doesn't have color on its own, but when applied to a pattern of pixels, can create color bands which makes the moire even more evident. Just as chroma noise is considered worse than luminance noise.
I'm sure someone will correct me if I'm wrong.
10-08-2013, 03:31 PM   #4
Sagitta's Avatar
Thats what I was thinking, but really theres moire, and.. well, moire. The description of 'other color artifacts" makes me scratch my head as as far as I know moire is about it unlss you start delving into the realm of chromatic aberrations.
10-08-2013, 03:53 PM   #5
There are color artifacts that have the same roots but don't look like classic moire patterns.
artifacts, camera, dslr, k-3, k3, pentax k-3, sensor
What do you think the replacement for the K-01 will be like? Glen_S Pentax Mirrorless Cameras 74 01-16-2013 09:47 AM
Don't get blinded by the purple fringing! slackercruster Photographic Technique 3 03-23-2012 07:41 PM
How do you fix the purple fringing from the 31mm Limited? Sperdynamite Pentax SLR Lens Discussion 59 02-26-2012 08:51 PM
FA50 F1.4 Purple Fringing like this expected ? photoleet Pentax SLR Lens Discussion 2 10-15-2011 07:01 PM
Trouble with the 31ltd - inconsistent AF and purple fringing DanielT74 Pentax SLR Lens Discussion 5 10-26-2010 02:58 PM
All times are GMT -7. The time now is 06:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
