Originally posted by jaad75 Are you sure, that the delay is right?
The delay I programmed in is accurate, basically all I had to do is compensate for the difference in shutter lag between the D4 and the K5IIs.
Originally posted by jaad75 I'm asking cause there is a way to trigger the flash with 1/200s (at least that's what camera and exif says) with absolutely no trace of the rear curtain and you have a lot of it shown at 1/250s.
The difference between 1/180th and 1/200th is trivial - though going from 1/180th to 1/250th is a bigger difference, with flash synced at 1/320th, slightly less than half of the frame is blacked out from the shutter curtain. At 1/400th three quarters of the frame is blacked out by the second curtain. My testing was done with the BRX flash unit at full power - the T=0.1 duration of the Elinchrom BRX ( which uses similar circuitry to the older BRXi units) is roughly 1/500th - the T=0.1 time with hotshoe flashes can be longer than this at full power.
