Originally posted by JinDesu Er, wait I'm confused. On the k-5/k-5IIs, I believe the way to swap the AF point was to hold the OK button until the menu switched, then choose your mode etc, then hold the OK button to get out of that menu. It should then stay in each menu until you quit out of it.
Are you saying on the 6D, if you try to go to the AF point select menu, it stays for a few seconds and closes on you?
On the K-5, when the toggle switch is in selection AF, the 4 way controller automatically controls where it is. Now here's the key of how I use it: I have it set in selection to one point to the right of center, so when I go to portrait mode on the street, I simply toggle the switch to selection, the cam remembers the last point I selected, and I line up the point with the face and I'm done.
I would find this to be crucial not only for my street shooting, but for my concert shooting and if it's not reassigned to even a function button, the K-3 will likely not be for me and I'll move on for my next buy. I need a second body, but I'm not averse to going to another company, since I just need a 35 and 50.
