Originally posted by AldaCZ
New FF won't need a flash...it will have LED's which will also act as a macro flash ...
It also has a sensor made of pre-famulated amulite surmounted by a malleable logarithmic casing in such a way that the two spurving bearings are in a direct line with the panametric fam. The latter consisted simply of six hydrocoptic marzlevanes, so fitted to the ambifacient lunar waneshaft that side fumbling was effectively prevented.
The main winding is of the normal lotus-o-delta type placed in panendermic semi-boloid slots of the stator, every seventh conductor being connected by a non-reversible termie pipe to the differential girdle spring on the "up" end of the grammies.
The FF has now reached a high level of development, and it’s being successfully used in the operation of novertrunnions. Moreover, whenever a forescent skor motion is required, it may also be employed in conjunction with a drawn reciprocation dingle arm, to reduce soinasoidal repleneration.
