Originally posted by Parallax Everclear is just pure grain ethyl alcohol. It should work well as a slovent.
We had 100% ethanol on the hospital formulary. It was for wound irrigation for people who were allergic to other antimicrobials. It could also be give to stop premature labor, but was rarely used for that. The interesting thing is that it was on the formulary as a Schedule II drug just like morphine and Demerol. The reason it was controlled is so it wouldn't inexplicably "dissappear".
Originally posted by dansamy I don't know how "pure" it is, but it sure is foul.
Originally posted by ZoeB In all fairness, you can't have stable 100% ethanol at STP, so 'pure ethanol' is more like 97%. But yeah, you can imagine how heavily regulated it is in Norway.
The Geothermal heating and cooling system in my house uses pure alcohol in the ground loops buried in the yard. There are two lines that go out about 100 feet to a header, then three loops 600 feet long each, buried about 9 feet down. This is the heat exchanger portion of the system where heat is either gathered to then use for warming the house, or heat is deposited when the system is cooling it.
I was there when the HVAC guy was filling the system. He brought in a couple of barrels with the alcohol, complete with documentation from the DEA. The stuff is supposedly 200 proof, and the DEA regulates it to prevent misuse.
I thought it smelled great, but it was very strong. When he opened the first barrel I was about 40 feet away, and smelled it instantly.
