Originally posted by rod_grant Old carpenter's maxim; measure twice, cut once.
It probably applies to drilling too: measure twice drill once.
Yep ...known that rule since I was 10. Add to it.....
"Forget it once and you will be sorry."
Originally posted by Racer X 69 Fill the holes with epoxy.
Then carefully lay it all out, and give it your best.
It will all work out.
The holes won't show, they were still within the covered area and I have the new ones drilled and they are on the money. Sloppiness on my part
...I will slow down today and try to avoid mistakes.....at least I didn't saw off an arm in my haste to get 'er done. Yep, it will work out...I'll make it all work out!
Otis has a big announcement to make today...not sure what it is, but I can guess?
He dropped a hint when he said.....
"Tell Jim and Donna to grab their contraband and rush down to Texas, the time is right."
Hard to believe that the end of Jan is going to be swimming weather! Otis says we owe it all to his tire burning contribution to Global Warming.
Regards!
I like the "Goat Stuff"...just don't let it "Get Your Goat"
EDIT: Forgot to add...
that drawing is copyrighted.....in case any of you thought of stealing it and making a Million $$$$ like that potato guy made.
