Show Printable Version 108819 Likes Search this Thread
09-23-2016, 01:29 AM   #29281
MarkJerling's Avatar
QuoteOriginally posted by savoche Quote
That was my thought, too, but then again, it's just a 10A/230V contraption. And from 1990.
I would have thought that would be 20A at least. Have you, at any time, replaced the element?
09-23-2016, 01:45 AM   #29282
QuoteOriginally posted by Racer X 69 Quote
At most homes the power is delivered at 220v single phase from the transformer. The main panel will have a 200 amp capacity with two 110v buses. For 220 circuits the two are combined.
Larger homes with higher load demands will have a 400 amp service, but the panel configuration is the same.
Businesses with high draw machinery will have a 440v 3 phase service. Essentially 3 110v circuits.
Really large businesses, like the factory I work in, have their own substation. The power going into the sub is 115,000v. What goes out, into the factory electrical system is similar to the substations that deliver power elsewhere, usually 17,500v. Then various transformers step the voltage down as needed for lightning and machinery.
Ha. That clears it up. Our main lines carry 220kV and serves substations from where supplies run out at 110 kV, 66 kV and 50 kV. From that step down to 230V per phase.
09-23-2016, 08:08 AM   #29283
Man With A Camera
Racer X 69's Avatar
Location: The Great Pacific Northwet, in the Land Between Canada and Mexico
Hopefully the new one will hold on to its smoke somewhat better
The plumbers were on time, polite, and well prepared. I'm trying to figure out what's wrong.
Plumbers?
Looks more like you need an electrician.
09-23-2016, 08:42 AM   #29284
Man With A Camera
Racer X 69's Avatar
QuoteOriginally posted by MarkJerling Quote
The main power distribution systems pass energy from the generation source to various parts of the country on high voltage transmission lines, typically 500kV and 230kV, such as the Bonneville Power Administration.
From the larger substations regional power companies (both public such an PUD's and private such as Puget Sound Energy) tap off with 115kV transmission lines for their regional distribution systems. Those transmission lines make up the backbone of each utilities distribution system. From strategically located substations the energy is stepped down to 17.5kV, and then lowered even more at each customer delivery point as required.
Working inside of power substations is interesting, but very dangerous.
Here is a video of a switch being opened at a sub with 500kV lines under load.
I've been in substations when switching is taking place. It is spooky. Also very dangerous, as the energy is looking for ground.
You don't want to be in the ground path.
09-23-2016, 09:17 AM - 2 Likes   #29285
Senior Moderator
Parallax's Avatar
One of the nurses I used to work for said "old people are like electricity; they always go to ground."
09-23-2016, 09:40 AM   #29286
Man With A Camera
Racer X 69's Avatar
QuoteOriginally posted by Parallax Quote
That's funny.
09-23-2016, 11:30 AM   #29287
Master of the obvious
savoche's Avatar
The stove is on a 20A and the rest are 10A as our electrical system is fairly ancient. When the time comes to refit everything the normal would be 16A for standard circuits and 25A (or 32A?) for technical circuits. We're also on a single phase, new installations are all 3 phases.
Plumbers?
Ah, no, there was no attempt at repairing the circuitry. They replaced the entire heater. 26 years was old enough, I think. Besides, at the hourly rates charged these days that was probably the cheapest solution anyway.
I'm just glad we didn't need the fire department...
09-23-2016, 01:54 PM   #29288
savoche's Avatar
Welcome back Bert! Well lets see... In the week that was:
Someone tried to make it a photography thread (Odd, I know!) then we ventured into tractors and lawns and lawnmowing before venturing to four wheel driving until Rob guided us back to food and before Savoche tried to burn his house down. I think that about sums it up. (Other than the topic you mentioned and which I won't comment about.)
Oh, I forgot.. But I didn't try to burn down my house. Or at least, I didn't try. If anybody did it was the previous owner. I've found a few "creative" solutions that he's left behind. I don't really like creativity when it comes to electric wiring. For some things in life following the book is the right thing to do.
09-23-2016, 01:57 PM - 2 Likes   #29289
savoche's Avatar
Of course, photography isn't one of those things. But then that's not relevant for this thread, is it.
09-23-2016, 02:12 PM   #29290
Man With A Camera
Racer X 69's Avatar
Without a doubt.
09-23-2016, 11:29 PM   #29291
Looks to me like the previous owner may have rewired the mains cable going in and got too much tension on the wires with the result that the insulation perished. Could also have stripped the insulation by nipping in with side cutters and pulling - stretching the plastic and damaging its integrity, forming the beginning of the perishing. Also, event though it appears to have been a plug-in appliance, because it is fixed to the wall, where I come from that is an electrician job. The rules there were that plug in appliances themselves and free cables were do it yourself but fixed wiring was electrician. So, an extension cord hung of cup hooks is 'not permanent' (do it yourself) but the same extension cord fixed with cable clips becomes 'permanent' and requires an electrician. Gets interesting with tricks like wiring a garden shed using an outdoor extension cable!
09-24-2016, 02:50 AM   #29292
savoche's Avatar
QuoteOriginally posted by tim60 Quote
I think we have much the same regulations here, but as far as I know it doesn't matter whether the appliance is fixed or not - what matters is if it's plug-in or permanently wired. And if it is fixed to a wall you're not allowed to use an extension cord. I never understood why an appliance not fixed to the wall implicitly is less permanent than one that is... But then again, it can't be easy to make regulations that make sense in all situations, either.
09-24-2016, 02:53 AM   #29293
savoche's Avatar
707 posts to go over the next 22 days to make 30,000 before our 3rd anniversary.
09-24-2016, 03:25 AM   #29294
For a moment there you had me worried that this is a factually correct thread!
09-24-2016, 03:26 AM   #29295
Don't move to the state of Victoria (Australia) where it's actually illegal to replace your own lightbulbs! Probably the nation's most broken law.
bacon, bagpipes, beer, breakfast, canada, catch 22, cheese, drink, dslr, ford, general talk, gin, guns, igunaq, k-3, k-mount, k3, kids, lutefisk, lycra, marital relations, pentax k-3, possums, sandwich, scotch, shirley, snoring, spam, squirrels, tokyo
why I will buy a K3 chicagojohn Pentax K-3 & K-3 II 80 09-18-2016 08:42 AM
Suggestion Neutralize the 'why I won't buy a k-3' thread crewl1 Site Suggestions and Help 61 10-04-2014 05:08 PM
Why I Won't Be Buying A K5IIs Racer X 69 Pentax K-5 & K-5 II 40 02-03-2014 08:12 PM
Why I don't buy Pentax lenses keyser Pentax SLR Lens Discussion 44 12-20-2012 01:58 AM
I feel so old: 8 things the facebook gen won't buy Nesster General Talk 27 04-22-2012 11:01 AM
All times are GMT -7. The time now is 08:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
