This road has a start and end.
If you go 200 miles an hour, and cross the start and end 200 times and are the first one to cross the end the 200th time you win.
That would be 500 miles, all while the only stops are to get gas and change tires a few times. You don't get out when you stop for gas and tires either.
Nope.
In fact, the seat belts go over your shoulders, around your waist and between your legs. And you have multiple layers of Nomex coveralls on, a helmet, and there is a net over the window, so getting out is a bit of a chore.
Besides, the stop for fuel and tires only takes about 12 to 14 seconds.
You don't even get to stop and pee.
No snacks either.
