Feels like a heatwave this morning compared to yesterday morning...instead of 14F it is 22F......Otis says this is due to the two big tractor tires he burned at 3am .
Cold is cold, and anything below 60F is cold.....even 60F is barely tolerable unless you have on a full set of thermals and a heavy jacket.
I need to get out and feed the animals, but for the past 20 minutes I have been enjoying watching a squirrel out my windows trying to break the ice in the water bowls. They are so funny and so determined. You can see their anger build as they work and work, jump up and down with their tiny bodies trying to bust through, nibbling at the ice like a madman as their frustration builds.
His latest effort was to climb up the tree and jump down on the ice to crack it open....Yep, it failed too and sent him into another fit of anger.....
I'll go out and get him some water...otherwise he will stay there all day if necessary, squirrels are not quitters...which is why there is no such thing as a "squirrel proof" bird feeder.
Regarding "looking busy".......The worst case I have ever seen was when I worked at the nuclear plant they built near here in the mid 70s. I was hired as a journeyman carpenter, though there was very little "carpenter work" at the site. My friend that hired me put me in that slot because it was the only one open that paid well. I should have been a pipe fitter, but there was no opening. I was definitely qualified for the carpenter position, over qualified in fact, but it is not what I wanted.
The plant was a total wreck full of inexperienced people and most of the jobs were like mine...obtained by favoritism and not qualifications. My foreman couldn't read blueprints.....and once resulted in a concrete pour 80 feet up in the reactor core that was at the wrong elevation and had to be jackhammered out and redone.......took two weeks to get it out at great expense. Yep...he kept his job. There were often long delays waiting for the next stage of work and our crew would be sent off in all directions to "look busy". Maybe just walking around the plant at a fast pace like we were going someplace important.
The worst thing was when the foreman pointed me to a stack of 1" A/A plywood, beautiful stuff, seven feet tall and told me to cut up every sheet into one foot squares. It took most of a day. I had no idea why...it was normally used for floor decking at the upper levels in the reactor core work areas. My shift ended and when I came in the next day all those plywood squares were in a dumpster. I asked him why??? He said "it kept you busy all day, didn't it?"
The plant had a 4 billion $$ cost overrun that consumers paid. In the buried trash pit there....which was huge...there were unimaginable amounts of stainless piping of all sizes and copper too. If you could own the trash pit you would be a multi-millionaire.
Taken to extremes, "looking busy" gets very costly, and the consumers almost always ends up paying for it.
Regards!
