How much time have I left? How many pictures do I want to take before then?
I've posted this philosophical notion before, maybe two years back, from Nikos Kazantkakis, "The Odyssey, A modern Sequel" which follows Odysseus from the slaying of the suitors until his death.
Life is like coming to a precipice where looking down you cannot see the bottom, and looking out you cannot see the other side, or even the horizon, just nothing, yet you must try to build a bridge across to that other side. No matter how carefully you build, your bridge will collapse before you can even see the other side, which may not exist at all, and you will fall into the abyss below, where there is also nothing, sharing the same fate as all the humans who have tried to cross the precipice of life before you. Yet you, and every individual before and after, must try to build your own bridge.
Better to exercise the Pentax and indulge your LBA,
---------- Post added 02-11-17 at 09:23 PM ----------
Originally posted by robtcorl When my urologist found early stages of cancer in my prostate, 6 years ago, he was aggressive in his approach, get that thing out of there!
I went through of a battery of tests to make sure it had not spread, and it had not.
So I got the Da Vinci robotic prostatectomy to remove it, and the results were that it was contained within the gland.
It's played hell with my sex life, but I'm alive and thankful for modern medical practices, right along with my pacemaker.
WPRESTO, I'm hoping yours stays in remission.
I had about four months of chemo (kept teaching during this), then radical prostatectomy (during final exams, so I had to give mine early), then three months of external beam radiation together with hormonal treatment (not teaching Spring semester = my last semester, while enduring this part). Hormones were the hardest - they mess with your mind and change your personality. I knew it intellectually, but I could not control it. Eventually they put me on an opioid drug that did improve my mood and made my company tolerable for family members, but I got off it as soon as they'd allow after the hormonal treatment ended.
