Originally posted by Racer X 69 Yes, you do.
Yes, you are.
Yes, it is.
You can do it.
All that is required is that you have to want it.
Easy.
No, it isn't.
A tragic thing about modern society is the sedentary lifestyle that automation has given us. And our bodies aren't designed to carry the extra load. I know how you are feeling. After college I worked in an office environment. When I would get home at day's end I barely had enough energy to fix dinner, let alone exercise. And after sitting at a desk all day I really needed to get some. And even though I moved to a blue collar job after only a few years, it was difficult to keep the pounds from piling on. I went from a skinny 130lbs to 150, 170, 190, 210 . . . . . . . When I started approaching 220 I got scared. About 3 years ago I hit 240.
That was it.
I've made it down to 180, and my goal is 160. But the last 3 months convalescing after foot surgery has made it difficult. I'm back up to 195, but I got the go ahead to wean off the cast boot today from the foot doc, and increased activity is on the agenda.
So good luck Scotty, I'm pulling for ya!
I kept the final total under 2,000 calories again. I also plan on getting to where I can get myself to 100 pushups and crunches again. Right now I am back down to only being able to do about 40 each. I imagine if I get this done not only will my 36 inch waist pants not be tight any more, but I will need a belt (or have to buy new ones), but I want to get into shape to do some real hiking this summer.
Originally posted by eddie1960 You can do it Scotty, I'll challenge you, I need to drop about 60 myself, I was almost there a couple years back and a job change and some other things took me back to 230. It takes a lot of work. I used an app to track my calories in and another to track what I burned (my fitness pal and map my fitness) up your water intake, and cut portion size are the two big takeaways for the start. If you haven't been exercising start by walking (someone I know went from 340 to 155 and his primary exercise is walking every day....he controls calories but eats what he wants just in a portion that works)
Pm me if you want to do a loss challenge (you should win initially between my two beat up toes and an Achilles injury my exercise is very curtailed)
Lets do it!
