Originally posted by bertwert I have an old Raleigh road bike not in the best conditions, a bit of rust, fraying cables, flimsy brakes, old tires, etc... The bike is fully rideable but could do with some work; this is the bike I used last year. Now I was considering restoring this bike fully; cleaning and painting frame, new cables, new brakes, new tires, new pedals, regreasing, outfitting with rack and bags etc... which would probably cost in the area of $150-$300? This would give me a nice steel road bike, which I can ride almost anywhere. I was planning on riding to school and back once the conditions are good (almost 30k away) so would need to be comfortable, durable, and capable of transporting lunch/books (hence the rack and bags). I have one major problem, my bike maintenance skills don't really exceed repairing a flat tire so I would probably learn a lot. Not sure if it is best for me to do this, it would be pretty easy to end with a pile destined for the junk yard.
I rode fifteen miles to work for about seven years
a road bike is the only way to go
mountains and hybrids are just too damn slow
downhill you are pushing 30-40mph
on the flats 15-25mph depending on the wind
at one point I was doing centuries under six hours (including breakfast and flat tires)
some of the old Raleigh's with lugged frames were quite nice
strong and light
rebuilding a bike can get very expensive
you want to pick what you change with care
light wheels and tires can alter the bike more than anything else you will do
there are some vey good books and videos available for the aspiring mechanic
luckily wrenching bicycles is more straightforward than you probably imagine...even I could do it
my advice on rebuilding is this
price out your parts then compare that to the price of a new bike
price the parts you need not what you want
unless you really want to rebuild, new is often cheaper
a good rack or racks to carry your stuff is better than trying to use a backpack
you want your load as low as possible
road riding also requires a good lightset
just because you can see them doesn't mean they can see you
from my own experience, just because they can see you doesn't mean they care
good luck
