Originally posted by robtcorl Never knew if this was a true story or just a story.
It supposedly happened several years ago.
A guy took his new Cadillac back to the dealer for a rattle.
After a test drive to listen for the noise, and concluding it came from the driver's door, they removed the door panel.
Inside was a string tied to a few steel nuts with a note attached that said, Well you found the rattle you rich son-of a b!tch, put there by someone at the factory.
There are lots of stories like that, and many are true.
I worked at a Ford dealer for a while in the early 1970's. A pickup came in for warranty work. Had a problem with oil pressure. Turned out there was a hamburger patty in the oil pan, that would get sucked up against the oil pickup screen while the engine was running, blocking the oil flow just enough to restrict it and cause a drop in pressure. Since it only had a few hundred miles on it there was only one way it could have gotten in there. The customer got a new engine, hold the pickles and relish, thank you.
Another was a Lincoln Town Car, that had a clinking noise coming from the rear. A Coke bottle was found in the gas tank. Now the filler neck isn't large enough for the bottle to have been inserted after the car was assembled, so the only logical source was the assembly line. The tank had to be removed and cut open to find the bottle. Of course a new tank was installed, sans bottle.
Factory workers are a notoriously unhappy bunch. Many spend their days concocting ways to 'get back' at the company for things perceived to be done to them by management.
