Show Printable Version 108807 Likes Search this Thread
10-14-2017, 01:46 AM - 1 Like   #41101
Man With A Camera
Racer X 69's Avatar
Location: The Great Pacific Northwet, in the Land Between Canada and Mexico
Oh, and I feel a rant coming on.
I stumbled on a discussion elsewhere here that had a mention of the Echo thing that Amazon is pimping in the name of home automation. It intrigued me so I did a quick web search.
Not a lot of stuff popped up, but this 'smart outlet' caught my eye.
Practical timing function, no good memory needed, easy managing household electricity. For example, you can switch off your desk lamp without having to walk close to it when in bed.
Chinglish.
What a language.
Nuff said.
(The fine print: OK, so ya wanna buy the Echo thing, and spend money on a whole bunch of other stuff, so you don't have to go walking around in bed and all, and that is OK. If it makes you happy, go for it. I can't fault you for that. It's your money. Enjoy it any way you want. But please, please, please, be careful while walking around in bed. And remember, no good memory needed. Ever.)
10-14-2017, 01:54 AM   #41102
Man With A Camera
Racer X 69's Avatar
Here's another one.
Um, I'm thinking it ain't such a great idea to cook breakfast in your bed. Well, at least for me, as I have a waterbed. Waterbeds and toasters don't mix.
Also, that stuff on the nightstand looks a little weird. An odd stuffed animal with a lamp sticking out of his neck?
Get a load of that water heater. Looks more like a commercial air freshener or an iTunes speaker dock. My hot water heaters (yes, there are two, one electrically connected, the other receives the preheated hot water from the geothermal heating and cooling unit sitting a few feet away) are in the basement, where they belong.
And who leaves their router out on the bookcase? I'm lazy and don't like to dust anything that I don't need to, so my router is in the basement, next to the ADSL modem, part of the structured media panel I put in when I built my house. Right next to the entrance package and the beaker panels (I have two on a 400 amp service). Haven't dusted it since I built the house 9 years ago.
10-14-2017, 05:13 AM   #41103
QuoteOriginally posted by Racer X 69 Quote
And this one followed it.
TOP 10 Homemade ENGINES - YouTube
Awesome stuff.
Makes me wanna work overtime shooting holes in airplanes so I can afford to get my race car going again.
are radials always odd numbered?
I read somewhere that radials were mounted horizontally as power plants for armored vehicles
10-14-2017, 08:02 AM - 1 Like   #41104
Tako Kichi's Avatar
QuoteOriginally posted by ccc_ Quote
Usually yes, where you see an even number of cylinders on a radial engine it is made up of two (or more) banks of cylinders with an odd number of cylinders per bank.
Some US tanks in WWII did indeed use radial aircraft engines as the power source and they were mounted horizontally under the rear deck.
10-14-2017, 03:43 PM   #41105
Otis Memorial Pentaxian
clackers's Avatar
There's quite a tradition of tank manufacturers looking to aircraft powerplants instead of trucks or tractors.
Even today the M1 Abrams uses the kind of gas turbine you'd put in a helicopter.
10-14-2017, 03:47 PM   #41106
Ex Finn.'s Avatar
This was the suggested video after Barney Nipped it in the Bud.
Crazy Engines - YouTube
That stinger is bad A$$.
10-14-2017, 03:52 PM - 2 Likes   #41107
Ex Finn.'s Avatar
One could cook Bacon or sear steaks on top of the exhaust shroud! That is if you don't mind taste of kerosene
10-14-2017, 03:55 PM - 1 Like   #41108
Ex Finn.'s Avatar
Awesome stuff.
Nice picture of the Z!
10-14-2017, 04:01 PM   #41109
Ex Finn.'s Avatar
a spritz of wd-40 or some silicone- or Teflon-based lube would have worked
I helped drill the weights for a cabinet clock that used lead ingots and that was the solution
works on brass and aluminum which aren't malleable but "sticky" as well
the second time I used brass tubing
heated it
drove it through the two inches of lead...lickety-split
when the tube cooled it was soldered in
cut off the excess tubing
peened over the ends
had much more abrasion resistant pivot for a shackle to fit in
after all of that, a neighbor suggested using the old crappy stamped sheet metal style of pilot+countersink bits
he was correct...with no flutes...no clogs
I have a set of those some where!
10-14-2017, 04:15 PM   #41110
Ex Finn.'s Avatar
I think I need counseling! Just spent a lot of time with my PC... 960 EVO m.2, 850 EVO SSD, some 4TB my-book thing from Best Buy and while there I had to force myself to put down that e-VGA GTX 1080.
Hence, I have been neglecting a pound of Bacon in the fridge that needs to be cooked.
10-14-2017, 04:41 PM - 3 Likes   #41111
Senior Moderator
Parallax's Avatar
This is the only thread I feel comfortable posting this in, so here goes:
Please, if you are inclined, pray for one of our members.
He's one of the best people I've ever had the privilege to know, and he needs our support.
Jim, we're with you. Hang in there!
10-14-2017, 05:04 PM - 1 Like   #41112
Ex Finn.'s Avatar
QuoteOriginally posted by Parallax Quote
Done.
10-14-2017, 07:01 PM   #41113
MarkJerling's Avatar
I hope he's not taken a turn worse? He is in our thoughts.
10-14-2017, 07:51 PM   #41114
Artesian's Avatar
Jim
He has my full support. Definitely hang in there. Continue to be defiant. It is in your spirit.
10-14-2017, 08:23 PM - 3 Likes   #41115
Rupert's Avatar
Maybe it was the loaded pickles that I sent you that made you light headed?
Thanks a ton...I can always use the prayers......we all can.
I know you guys are all with me, and have been, and my appreciation is beyond my capability for words.
You know what they say..."Life is a beach and then you die".......or something like that? Hey guys, they are not kidding us! For however long I can continue to function in a reasonable manner, I will be here to take advantage of the vast wealth of knowledge this thread has to offer.......rotary engines in a tank...where the hell else are you going to learn stuff like that!
No use in getting all grim faced and negative....I am not facing anything billions of others have not already faced...and what everyone else here will surely face too. Life is full of reality...some of it we would rather deny, but in the end that is not possible.
Best Regards!
bacon, bagpipes, beer, breakfast, canada, catch 22, cheese, drink, dslr, ford, general talk, gin, guns, igunaq, k-3, k-mount, k3, kids, lutefisk, lycra, marital relations, pentax k-3, possums, sandwich, scotch, shirley, snoring, spam, squirrels, tokyo
why I will buy a K3 chicagojohn Pentax K-3 & K-3 II 80 09-18-2016 08:42 AM
Suggestion Neutralize the 'why I won't buy a k-3' thread crewl1 Site Suggestions and Help 61 10-04-2014 05:08 PM
Why I Won't Be Buying A K5IIs Racer X 69 Pentax K-5 & K-5 II 40 02-03-2014 08:12 PM
Why I don't buy Pentax lenses keyser Pentax SLR Lens Discussion 44 12-20-2012 01:58 AM
I feel so old: 8 things the facebook gen won't buy Nesster General Talk 27 04-22-2012 11:01 AM
All times are GMT -7. The time now is 06:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
