Originally posted by Racer X 69 It is a simple job to remove the wheels, blow the sensors clean with a combination of some spray brake cleaner (available at your local auto parts store) and compressed air.
I need to make sure everyone understands that even though today's brakes should not have asbestos in them, the dust generated may still be bad to breathe.
That is why you need to wash the stuff down with the brake cleaner I mentioned. You can also make your own, mix up a batch of simple green and pour it into a spray bottle.
Cheap, and effective.
Then blow dry with shop air.
