Originally posted by robtcorl WinBlows 10
You should be able to adjust the text size via the control panel. I know that in WinBlows 8 and WinBlows 10 (both very similar and considerably different that prior WinBlows versions) the control panel is not easy to access, but it is there.
You should also be able to configure the desktop to look like the classic WinBlows desktop, with the taskbar at the bottom and the familiar start button and other controls.
Also, if you right click on the desktop, and select "Personalize", then "Display" there should be an option for adjusting the size of stuff on the desktop.
