Originally posted by Racer X 69 Boy Scout Juice.
I already told you - Boy Scouts never use accelerants to start a fire.
The inside of the bark from a down-wood log is often dry enough to scrape tinder from. Or you can Be Prepared and carry a tin of scorched cotton patches from an old dress shirt or dryer lint in a zip-close bag if you know it is going to be that damp.
It might take 15 minutes to get a small cooking fire going rather than 15 seconds. Been doing it for 50 or so years.
A real man uses only one match*.
* I carried a piece of chert and a steel in my patch tin for many years for just grins (hard to do right) but it left with the Suburban when I traded it in. I replaced it with a magnesium block and a striker (piece of cake). I can get a fire going with a firebow and bowdrill and cottonwood tinder (jute also works) but that's for exhibition. There are so many easier ways to do it.
For a quick 'n dirty fireplace or stove fire balled up
single sheets of the Wall Street Journal under the grate work very well - better than regular cheater paper. Something about the WSJ newsprint makes it burn longer and hotter than the soft stuff most newspapers use. Keeping a supply of fatwood slivers next to the hearth is also helpful. One sheet of newsprint and two or three slivers will do the trick if the split wood is dry.
