10-24-2013, 12:21 PM   #46
Lens Buying Addict
monochrome's Avatar
QuoteOriginally posted by GeneV Quote
The space required is minimal, since the SD memory and plastic case would not be required. Not much in there after those elements are removed.
As to the speed of the card, whatever the current speed of the FLU card, by putting the tethering on the SD card, Pentax effectively froze the speed and size of the card at the capabilities which FLU puts on the card in 2013-2014, and no WiFi card I have ever seen was the largest or fastest available even at the time. Even if it were, it would likely be surpassed quickly by new offerings. Tying two unrelated functions is usually a problem.
Since I'm not an engineer I can't rebut your argument. I'm sure there is some legitimate business reason the Ricoh / Pentax product manager would select an imperfect solution as a half-step to get quasi-Wi-Fi into the camera. I'm confident they are reasonably smart, motivated businessmen. If they haven't moved forward with this technology by the next realease I'll be more concerned.
10-24-2013, 12:37 PM   #47
disco_owner's Avatar
I really like the idea of panoramic assist mode even with camera attached to a nodal slide on a tripod ,, I want to be able to capture a scene with minimum amount of shots either vertical or horizotal images and be able to view the jpeg result on camera or using the tethering on a tablet.
10-24-2013, 01:49 PM   #48
As mentioned in another thread, the regulatory demands of Wi-Fi communications are specific for different jurisdictions. You get into radio frequency issues. The card manufacturers deal with, or have dealt with these. So Ricoh decided to let them worry about that, and focus on the camera functionality.
11-02-2013, 12:02 PM   #49
Col
Col's Avatar
OK had the K-3 for half a day:
I would like the meter mode button just to cycle through the three options on successive pushes, rather than (or as well as) being a hold down and rear edial combo.
Can I have level display back as an option on the Fx.
11-02-2013, 03:01 PM   #50
Another new K-3 owner voting to have the electronic level restored as an option for the Fx button. I use/used that constantly.
11-02-2013, 04:29 PM   #51
Allow mechanical SR for video. They implement it in the K-5 but not in the K-3? They decided to use the K-01 digital SR?
11-02-2013, 11:20 PM   #52
Col
Col's Avatar
Live view... AF focus whilst zoomed in, back please, and a fast way to recentre the Live view focus area.
Catch in focus.
When this option is set, need the in body focus type to default to AF.S and not MF (when a manual lens or a Len's switch set to MF) At present the body being in MF prevents the AF button from driving focus nor the IR remote being able to prime the camera for focus trapping.
11-04-2013, 01:33 PM   #53
QuoteOriginally posted by Col Quote
When you're in Select focusing mode in Live View and are moving the focus area around (white square with the arrows on all sides), pressing the Green button recentres the focus square.
11-04-2013, 03:40 PM   #54
Col
Col's Avatar
QuoteOriginally posted by Bogartist Quote
Oh yes page 47... and the icon is pretty obvious
11-04-2013, 06:56 PM   #55
@Col - Pretty sure that is how every previous Pentax DSLR has implemented CIF. Focus selector had to be in AFS and lens had to be either fully manual or the switch set to manual.
Jack
11-04-2013, 09:53 PM   #56
QuoteOriginally posted by RonHendriks1966 Quote
I would like to have some more controll over the interval movie recording.
- Why is there no option for a 1 second interval (where there is on the K-01)?
- Making the interval selectable with a dial would be great. So not just the presets off 2, 5, 10 or 20 seconds and on, but really selectable, it is just a timer. With steps off one second, we could also choose 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 15, 20, 25.... and so on intervals in seconds between every shot.
Maybe an update to the K-01/K-30/K-50 to give them the 4k interval movie.
Ron - I just had a look at the interval shooting timing selector on my new K-3. There is one second resolution available.
Jack
11-04-2013, 11:17 PM   #57
Col
Col's Avatar
QuoteOriginally posted by jbinpg Quote
Jack
Indeed you had to be in AFS. My point is the camera goes into MF... and it is not an option to change it. That was why I'm asking for it to go to AFS if the Catch-in-focus is option is set to yes.
11-04-2013, 11:24 PM   #58
Doesn't seem logical to me to enable AFS while using CIF. You are setting a focus point manually and then either waiting for a subject to walk into the focal plane or moving the focal plane physically to trigger the shutter when focus in achieved. So I can see why Ricoh did it this way.
Jack
11-04-2013, 11:28 PM   #59
scole's Avatar
Finally got my pre-ordered body today. I just wish some buttons would take a more direct path to items like they did on the K-5. Examples-
I've assigned the RAW/FX button to bring up the exposure bracketing dialog and I frequently switch between this and the self timer. On the K-5, the option "cursor" defaults at the top level of navigation making it quick & easy to switch betwen the various options:
On the K-3, it seems to default to the deepest level of navigation. So- if I want to navigate from exposure bracketing to self timer, I have to click UP->UP->LEFT->LEFT. On the K-5, this was just LEFT->LEFT.
Also, when in playback mode, I like to cycle through the various options by pressing the INFO button. On the K-3, this bring up a list of choices and you have to scroll to which one you want. I want this to return to continual INFO button presses to cycle through the various modes.
11-05-2013, 03:24 AM   #60
Dreaming about more Users modes...
on K5 i've got 5 Users and it was'nt enough so just 3 is really not enough !!!
camera, dslr, k-3, k3, pentax k-3
New Firmware for K-500, K-50, K-5 II, K-5 IIs, K-5, K-30, K-01, K-r, and 645D is out Adam Pentax News and Rumors 60 09-16-2013 05:46 AM
K-5 II replacement wishes? Louicio Pentax K-5 14 07-05-2013 02:02 PM
K-01 Firmware update wishes! RonHendriks1966 Pentax K-01 65 01-13-2013 06:12 PM
k-5 firmware same as k-5iis firmware? grant richie Pentax K-5 2 12-09-2012 12:15 PM
K-7, Firmware 1.3, software bug?? bymy141 Pentax DSLR Discussion 6 04-18-2010 05:52 AM
All times are GMT -7. The time now is 07:15 AM. | See also: NikonForums.com, part of our network of photo forums!
