Originally posted by raider On the K-3's D-BG5 grip, the AF button is at the top and the green button is at the bottom....which also resemble the K-3's arrangement such that the AF button is placed above the green button....
You are correct, but to me the important part is where the buttons are relative to the rear dial.
The default position for my thumb is over the AF button.
On the K-3 body, I'd have to move the thumb to the left to find the rear dial (see below).
In contrast, on the D-BG5, my thumb would have to move to the right (and up) to find the rear dial.
Say, I'm shooting in landscape orientation and move my thumb between rear dial and AF button to adjust the aperture and focus respectively. Now I'm turning the camera to portrait mode and if I continued the same movement pattern with my thumb, I'd be moving between rear dial and AE-L button.
Or when shooting in portrait orientation and switching between rear dial and AF button, a change to landscape orientation would lead me to operate rear dial and green button if I continued with the same movement pattern.
I find that changing orientations sometimes has to happen very quickly when you shoot documentary style and the last thing I want to think about is what movement pattern my thumb should be exercising right now.
I hope I explained myself better now. EDIT: Maybe I should add that I use the AF button and the rear dial without taking my eye off the viewfinder. All this adjusting must occur "blind". I'm still somewhat in disbelieve that they found no better solution for the grip button layout and combined this with the absence of a button remapping feature.
