Show Printable Version 16947 Likes Search this Thread
11-19-2015, 12:12 AM - 4 Likes   #5086
LeRolls's Avatar
DA 15
11-19-2015, 09:55 AM - 1 Like   #5087
Canada_Rockies's Avatar
Lovely, Christopher. The lighting is just perfect. You must have a really good camera
11-19-2015, 02:11 PM - 1 Like   #5088
csa
csa's Avatar
Wow! That photo is absolutely stunning!!!
11-19-2015, 02:19 PM - 1 Like   #5089
rayallen's Avatar
QuoteOriginally posted by Canada_Rockies Quote
He does. He has a K-3.
11-19-2015, 09:39 PM   #5090
LeRolls's Avatar
Thank you. I got lucky that the sun popped out for a few minutes after the storm before dipping below some clouds again about five minutes later. Yes, half the time the K-3 takes the pictures all by itself. Doesn't even need me. Helluva camera that one!
QuoteOriginally posted by csa Quote
I'm gonna assume that you mean my picture and just say thanks.
QuoteOriginally posted by rayallen Quote
Yes, the K-3 punches well above it's weight class in many regards.
11-19-2015, 09:58 PM   #5091
QuoteOriginally posted by LeRolls Quote
Sure helps to live in Florida!!! I'm jealous....
11-20-2015, 07:28 AM   #5092
Agree, it was a great shot! Now, can I get some coaching? You chose f/16 for aperture yet I've seen in various posts that one shouldn't set an aperture that small to avoid diffraction. Can you walk us through how you settled on shooting parameters? Thanks in advance.
11-20-2015, 10:13 AM   #5093
QuoteOriginally posted by IchabodCrane Quote
[RANT]
Pixel peepers often worry about the degradation of an image for a zillion crazy reasons. Diffraction is one of the silly reasons. Yes, diffraction will reduce the detail and contrast of an image. I just had a quick look at the DoF Pro app on my phone, and a 12 mm lens shows the diffraction limit half way between f/8 and f/11 at hyperfocal distance. But we are talking about two different things. The app is great, but I disagree with the diffraction limit they put on it.
Diffraction does degrade an image slightly. Oh, really? That does not include everything one needs to know about the limits of an image. There is an awful lot of overly technical analysis out there. Some of it sounds as if it should make sense but does not. The diffraction limit is one of them. Let me give you my thoughts about it, and you can then shoot me down.
240 dpi is enough for a print. Pixel peepers say that 300 dpi is the ideal, but ... I have printed a K10 image at 20x30 inches, and it was, to put it bluntly, gorgeous. The image from a K10 is 3872x2592 pixels. At 300 dpi, that is a clean print 12.9" by 8.64" where each an every pixel will be distinct if the image is taken using the MTF program: the sharpest f/stop in the bunch. My best selling image is 16x24 inches in gallery wrap, which means one has to add another inch each end for the wrap, making the actual print 18x26 inches. OMG! you cannot print that big!!!!
My take on all this? Go for the depth of field if you need it. How about the K3? 6016x4000 at 300 dpi is a clean perfect pixel peeper special 20x13.3 inches. Use 240 dpi and the perfection goes out to 6016/240 = 25 by 4000/240 = 16.7 inches.
And then you go for depth of field. What is it, really? It is an 8x10 inch print viewed from 10 inches away that looks sharp. That's the depth of field. It is based on the resolution of your eye.
FINAL ANALYSIS: To heck with the pixel peeping idiots. If you need f/22 with your 10mm lens, use it. If you look at a 20x16.7 inch print from 10 inches away, it might not be absolutely crisp, but who in their right mind looks at a 20x16.7 inch print from 10 inches away?
[/RANT]
11-20-2015, 10:35 AM   #5094
normhead's Avatar
In the filed, I have found the practical limit to APS-c is ƒ22. I have several times shot multiple frames at different apertures from 2.8 to 22 and there have been a few instances where ƒ22 is simply the best image. Period hands down, no spin.
For the techies here's why that is true. The big issue in prints and images with regards to subject clarity is resolution. If you shoot at ƒ4 or ƒ5.6 , the sweet spots for subject resolution, it is quite possible 75% of your subject will be out of focus. You actually have a better image, and get more resolution accepting an image that is mildly reduced on resolution, than accept huge out of focus areas that have no technical resolution.
The difference between ƒ5.6 and ƒ8 in terms of focus point resolution is probably not detectable by the human eye on a web size image or a print, although it is measurable on test patterns.
The diffraction limit determines where the lens will be sharpest, but when combined with Depth of Filed is only one of the factors in determining how to get the sharpest subject. You always have to make trade-offs. I've never had an APS-c image that was good at ƒ32... but that is the only setting on APS-c that can't in the right circumstances give you the best possible image.
11-20-2015, 03:12 PM   #5095
WPRESTO's Avatar
When I gave a program at the local camera club on macro, where DOF is a real problem, I advised them that the apparent detail gained by going to f16 or even f22 far outweighed the technical loss of IQ caused by diffraction. For macro, the greater DOF imparts a visual impression of greater detail & sharpness, even if pixel-peeping reveals softening caused by diffraction.
11-21-2015, 06:04 AM   #5096
Scorpio71GR's Avatar
Experimenting with some high ISO
DA*16-50 ISO 8000
ISO 100
My need for full frame keeps diminishing with the K3, despite what the ASP-C haters say.
11-21-2015, 11:07 AM   #5097
QuoteOriginally posted by Scorpio71GR Quote
DA*16-50 ISO 8000My need for full frame keeps diminishing with the K3, despite what the ASP-C haters say.
I will say again - having said it in other places - that the FF vs APS-C argument was 120 vs 135 in my earlier days. Exactly the same problems. As the new films get finer and finer quality the difference becomes meaningless for most people. If I were a pro wedding shooter, it would be the 645Z, not a so-called full frame camera. (I think full frame is 11x14 inches, myself). I think I have to add curmudgeon to my signature ...
11-21-2015, 12:28 PM   #5098
zzeitg's Avatar
FA* 80-200
11-22-2015, 09:33 AM - 1 Like   #5099
LeRolls's Avatar
11-22-2015, 02:43 PM   #5100
Your best yet I think.
australia, auto, bittern, da, dslr, exposure, fa, flickr, info, iso, jpg, k-3, k-3 ii, k-3 iii, k3, k5-iis, morning, pentax k-3, photography, pics, pm, post, sample, shot, shots, sunbird, thread, wb
Pentax Q street shots - post them here. barondla Pentax Q 254 04-22-2016 05:46 PM
Suggestion Create ONE thread with K3 sample shots to make it easier to navigate jpzk Site Suggestions and Help 2 10-31-2013 07:51 PM
DA 55-300 Sample Shots (x7), no post processing cputeq Pentax SLR Lens Discussion 15 07-04-2008 01:01 AM
Post Your Eclipse shots here. vievetrick Post Your Photos! 34 02-25-2008 08:14 AM
Spring! Post your Motorcycle shots here! slip Post Your Photos! 33 04-28-2007 05:18 PM
All times are GMT -7. The time now is 11:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
