Originally posted by normhead Very nice.
Originally posted by WPRESTO No one will deny you a license to be proud of that one. Outstanding snowflake macro.
Originally posted by Scorpio71GR Another outstanding macro there.
Originally posted by bobbotron Very nice! I haven't been keeping up, has your new and improved flash setup helped out with these stacked shots?
Thanks all!
bobbotron: the new setup kind of helped. I'm still learning what works now that I have many more shooting options. Here I used my old Yongnuo YN560-III with the Godox PB-960 external battery pack. I shot continuous medium (4.5fps) bursts at 1/16th. At these settings I
could actually have used the Yongnuo by itself - at CM, it only starts missing frames at 1/16+0.3, and misses quickly at 1/16+0.7. But with the power pack, the thing is just rock solid, and in the future I might also turn the flash power back up a bit more. (1/16th is lower than usual for me.)
BTW, shooting deeper stacks at higher fps also allows me to open up the lenses quite a bit more, and I can see the effect this has on the resolution of my flake shots. In the past, I would typically shoot F/13 (or even higher) on the reversed lens and F/8 on the primary. But shooting those apertures for high magnification (over 2:1) work, you get some not insignificant diffraction. This time I used F/8 and F/5.6.
As an aside, what is now bugging me is no longer the flash, but the K-3's liveview implementation. It turns out that when you fire a continuous volley, liveview is no longer live. It only displays the last shot fired (if you have Instant Review on), or the screen just goes completely dark (if you have Instant Review off). So at Continuous Medium, you're looking at an image that is more than 0.2s behind whatever your camera is currently pointing at. This makes it very hard to use visual feedback to control your motion in order to get a smooth continuous movement. So I tried to rehearse my movement before firing a volley, but it's still pretty hard. If I had a
tad more ambient light (or opened up the reversed lens even more), I just might be able to use the OVF instead of liveview, but as is it was still too dark to be usable, IMHO.
When you combine the higher fps (more shots per volley), the quest to find nice flakes (try many potential subjects), and shooting many bursts per subject (to make sure you you have one that is stackable, and also because tiny changes in angle really change the way the flakes "light up"), you really pile on the actuations. This one time, I fired around 500 frames in probably 50-60 bursts. I've so far put seven bursts through the stacking, with one published "shot" and possibly a second candidate...
