01-20-2014, 03:41 PM   #871
normhead's Avatar
From my Saturday walk with.. cross posted from Post Your Photos. Sigma 8-16 and DA 18-135. Exif is not stripped, so you can download and view exif.
Leaving town for the park, the gas station with restaurant and the Mad Mucher Restaurant both had their parking lots full with snow mobiles.
At the car park, dog sledders are waiting to take some people out for some overnight winter camping.
Heading out on the trail.
The Big Pine
A spruce bog..
Stopping in to see the Jays...
01-20-2014, 03:48 PM   #872
EricBrown's Avatar
Sunrise at USAF Memorial taken with 10-17mm Fisheye. Old Church take with DA*16-50.
PENTAX K-3  Photo
PENTAX K-3  Photo
01-20-2014, 04:46 PM - 1 Like   #873
Bob from Aus's Avatar
We had recent fires in Southern Australia. This is the sun at 5 pm in mid summer shrouded by cloud and smoke. K3 with 500mm sigma.
Temperature was starting to cool down from the 44C or 112F.
PENTAX K-3  Photo
01-20-2014, 04:50 PM   #874
A few from Killarney today. -30 but K3 keeps on shooting
01-20-2014, 06:21 PM - 1 Like   #875
Virtuoso Violinist - David Garrett
01-21-2014, 01:01 AM - 2 Likes   #876
dcBear78's Avatar
Stitched Panorama using FA31
01-21-2014, 05:46 AM   #877
SkipperRi's Avatar
QuoteOriginally posted by mattb123 Quote
If long exposures aren't a problem for you always shoot in ISO 100 (which may require a tripod).
If they are a problem then just increase the ISO as much as you need to get the required shutter speed, but no more.
If using auto ISO, I'll set it to 100-3200 or 100-1600 but sometimes it will pick a higher ISO than you may need, especially if you are using a tripod. In those cases I set it my self to the lowest value that would work for that particular shot.
Thanks matt, I usually do exactly that.
01-21-2014, 05:46 AM   #878
SkipperRi's Avatar
01-21-2014, 07:46 AM   #879
tabl10s's Avatar
QuoteOriginally posted by SkipperRi Quote
Based on yours experience, what's best choice in ISO settings? I shoot only RAW, so, should I go to NR on (and on which value) or of, and which setting (slow, green, fast) is the best in Auto ISO Parameters?
Auto ISO is supposed to be pretty strong on the K-3 and Ed from "Photouniverse" sez to turn it off to maintain sharpness.
01-21-2014, 08:32 AM   #880
SkipperRi's Avatar
QuoteOriginally posted by tabl10s Quote
You mean that the best solution is to turn off NR completely or just for higher ISO?
01-21-2014, 12:22 PM   #881
The NR settings are there in-camera, so it makes sense to use them. The Pentax engineers did a decent job in making the high-ISO NR work effectively. Using those options comes at almost no cost to sharpness if you apply the settings moderately.
I shoot RAW+ , but for the JPEG output I set the High-ISO NR to kick in gradually. I have JPEG NR turned off until IS0 1600, then Low until ISO 6400, then Medium from ISO 6400 up. I've been using pretty much the same conservative high-ISO NR settings on the K-x and the K-5 for years.
01-21-2014, 12:43 PM   #882
SkipperRi's Avatar
I shoot RAW+ , but for the JPEG output I set the High-ISO NR (for JPEGs) to kick in gradually. I have JPEG NR turned off until IS0 1600, then Low until ISO 6400, then Medium from ISO 6400 up. I've been using pretty much the same light high-ISO NR settings on the K-x and the K-5 for years.
Thanks for clarification, my friend. I shoot RAW only, so, based on your experience, should I go with similar NR settings that you using for JPEG pictures, or you have some other advice?
01-21-2014, 12:57 PM   #883
normhead's Avatar
QuoteOriginally posted by john5100 Quote
What's the ISO on these John?
01-21-2014, 12:58 PM   #884
By all means try those settings and see if they work for you. But the best settings will depend on the subject and your shooting style. Landscape probably won't require the same NR or other camera settings as shooting live music, for example.
01-21-2014, 01:07 PM   #885
SkipperRi's Avatar
Absolutely, every scene require different approach. Just now I set NR settings just like yours, only different is, as I mentioned that I shoot RAW only. Now in the next few days I must do tests in higher ISO. BTW, what software is the best for NR in PP. For now, I'm using Lightroom. Is there better solution?
Thanks for the answers and helping!
australia, auto, bittern, da, dslr, exposure, fa, flickr, info, iso, jpg, k-3, k3, k5-iis, morning, pentax k-3, photography, pics, pm, post, sample, shot, shots, sunbird, thread, wb
Pentax Q street shots - post them here. barondla Pentax Q 254 04-22-2016 05:46 PM
Suggestion Create ONE thread with K3 sample shots to make it easier to navigate jpzk Site Suggestions and Help 2 10-31-2013 07:51 PM
DA 55-300 Sample Shots (x7), no post processing cputeq Pentax SLR Lens Discussion 15 07-04-2008 01:01 AM
Post Your Eclipse shots here. vievetrick Post Your Photos! 34 02-25-2008 08:14 AM
Spring! Post your Motorcycle shots here! slip Post Your Photos! 33 04-28-2007 05:18 PM
All times are GMT -7. The time now is 07:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
