11-02-2013, 10:41 PM   #1
k3 interval shooting = great noise reduction
Just got my k3 tonight and was putting it threw some tests. I was trying some high iso tests and playing with the interval shooting. I found that if you shoot a single shot at 12800 and then compare it to a 12800 interval of 8 shots set to average, the noise reduction is incredible. Way better then using in camera noise reduction. Try it at 52,000 and results were even more amazing. Could pull a much cleaner image this way then trying to use in camera noise reduction or Lightroom noise reduction. The image does end up a hair softer though but that's at 200 zoom. Tried the test at 2000 iso and it works there too but Lightroom can easily handle that noise almost as well. But interval and Lightroom is a great combination.
Anyone else confirm tried this? I tried a 19 shot average but at some point the averaging doesn't improve it any more. I think it's somewhere between 6-9 shots seems to provide the best results. Attached is a 12,800 with some Lightroom sharpening and a bit of noise reduction.
Wayne
11-02-2013, 10:48 PM   #2
JohnBee's Avatar
Looks good.
I seem to of read the same figures on the theoretical frame limit(8) for improvements.
Having said that, multi-frame noise reduction works very well, though I have yet to find a practical use for it against that of a slower shutter and lower ISO myself.
11-02-2013, 10:54 PM   #3
QuoteOriginally posted by JohnBee Quote
Looks good.
Handheld night shots.
11-02-2013, 11:03 PM   #4
Sony has had a neat implementation of this for years. It works quite well on NEX and RX100 for static scenes at night or in poor lighting when you don't have a good tripod or monopod around. It can also broaden the dynamic range of an image considerably in any lighting. Downside is that it only creates JPEGs. I guess doing it in the K-3 does the same.
11-02-2013, 11:08 PM   #5
QuoteOriginally posted by Wayneheim Quote
Wayne
Multi-frame NR is extremely effective. If you put it through a program like arcsoft you can virtually remove the noise completely!
11-02-2013, 11:22 PM   #6
Wayne
I have not confirmed it but it seems consistent with the theory that noise is random, so averaging of several must reduce noise. The number of frames which makes sense would confront the problem of change of the image from frame to frame - either from camera movement or subject change. Analogs of this noise reduction method have been used in electronics for many decades. Interesting that the first place I encountered this was in a low noise amplifier for moving coil cartridges for playing vinyl records (remember them) - there were 8 transistors in parallel to cancel out the effect of noise in each. I never thought if there was a theoretical limit to the number which could be used or if it was just a practical 'diminishing returns' based limit to adding more - given that each additional transistor would add cost and other issues.
Also, to avoid camera movement over an extended time one would need a tripod, so why not use a lower ISO and the noise problem goes away.
This method cannot address the problem of low light AND fast changing subject.
11-02-2013, 11:27 PM   #7
QuoteOriginally posted by tim60 Quote
Stacking software will line up the slightly different images (from handheld motion) and remove the noise. Works very well. But yes, static subjects only.
11-03-2013, 12:44 AM   #8
Is it possible to do this on a K-5? I've tried doing underexposed multiple exposures, like Sony does, but haven't seen much improvement.
11-03-2013, 05:05 AM   #9
noVICE's Avatar
Can you do this with RAW files in Photoshop or lightroom?
11-03-2013, 05:16 AM   #10
QuoteOriginally posted by noVICE Quote
Yes. You stack the files in layers and give individual opacity to the different layers.
11-03-2013, 05:30 AM   #11
QuoteOriginally posted by Giklab Quote
Derped a lot here. Thought you could do it in-camera.
11-03-2013, 05:33 AM   #12
noVICE's Avatar
QuoteOriginally posted by timcatn Quote
Thanks! I can't wait to get this a shot.
....sheesh, I should have thought of that....need more sleep.
11-03-2013, 06:29 AM   #13
Alfie's Avatar
sqrt(N)
S/N by averaging random noise is expected to improve by the square root of N. Four shots should give a reduction by 2 – or 2.83 for 8.
19 should still give a 54% improvement over 8: 100×(√19/√8–1). In astrophotography stacking many images is not uncommon.
11-03-2013, 08:52 AM   #14
This is more of a technique thread than news or rumors. Mods?
11-03-2013, 09:28 AM   #15
maxfield_photo's Avatar
Actually the camera is capable of doing this with no external software, just set it to multiple exposure mode, and squeeze of as many frames as your heart desires. Works in Raw or Jpeg, but in Raw, the displayed color temperature will be something goofy like 2 billion degrees kelvin. The image will still look fine.
camera, dslr, image, interval, k-3, k3, lightroom, noise, pentax k-3, reduction, results, shot, tests
Pentax K10D long exposure noise reduction when shooting RAW? Robert S Donovan Pentax DSLR Discussion 30 08-19-2013 11:42 AM
Interval shooting shudderbug9 Pentax K-30 & K-50 10 01-08-2013 08:32 PM
Interval shooting mamethot Pentax Q 11 10-20-2012 08:43 PM
Interval Shooting FragileBird Pentax K-30 & K-50 4 08-23-2012 01:16 PM
Interval shooting trapa65 Pentax K-5 & K-5 II 2 03-22-2012 05:38 AM
All times are GMT -7. The time now is 07:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
