11-06-2013, 06:57 PM   #16
Good question, I don't think so, but?
David
11-06-2013, 07:16 PM   #17
Hey konra, I have noticed exactly the same thing. No idea why though.
11-06-2013, 08:14 PM   #18
Are you sure the flash is firing twice? Have you tried it in A mode?
11-06-2013, 08:22 PM   #19
With the external flash, put the camera mode dial to X, manually set the ISO to 200, focus, and see what happens.
11-06-2013, 10:39 PM   #20
Is the camera in wirelss flash controller mode with the inbuilt flash set to "not contirbute to exposure"?
11-06-2013, 10:46 PM   #21
Dr_who's Avatar
QuoteOriginally posted by John Cafarella Quote
That option is not in the settings anymore. Now its much easier ... once you find it. Just press the flash on the d-pad and at the end the last two options is like Master and controller.
11-07-2013, 05:18 AM   #22
QuoteOriginally posted by konraDarnok Quote
Pretty straight forward test. Take picture, pop up the on board flash and take picture.
What's going on here? EXIF says "flash manual" but it's not on the flash manual setting. It's on the "flash on setting" with 0 compensation, which previously never underexposed like this. I tried "green mode," and it does the same thing. Bug?
Also, just mounted my AF-360, same result.
I've gotten the same thing on mine.
11-07-2013, 06:42 AM   #23
konraDarnok's Avatar
QuoteOriginally posted by Nostrildamus Quote
I'm coming to the opinion we have defective cameras.
11-07-2013, 06:51 AM   #24
The EXIF has masses of detail that we are missing in the images posted. The EXIF may give some information about what is going on. Could you pls post a straight-out-of-camera JPEG (not one put through Lightroom or Photoshop, with the bulk of the EXIF removed like the ones on display here) of a failed flash image.
Or post the text of the full EXIF extracted from a flash fail image (via the latest exiftool) as a text file attachment.
It may not provide all the answers, but most cameras collects buckets of data in the EXIF, so it is worth a close look. The K-3 in particular collects truck loads of data in the EXIF.
11-07-2013, 07:06 AM   #25
Sure, later today after work. I assumed the light room exports would maintain all the data. I guess I was wrong. I'd certainly like to fix this rather than go through the trouble of returning it, but I'm pretty sure this camera is just plain broken somehow. Figures I'd be the first on the forum to really have a problem after reading so many glowing reviews.
Other than the flash issue, everything else seems top notch, from image quality to improved auto-focus speed.
11-07-2013, 07:27 AM   #26
Who uses the pop-up flash?
11-07-2013, 07:40 AM   #27
QuoteOriginally posted by tzeentchiangod Quote
I do, sometimes. It's handy. Dial down the flash compensation -1 or -0.5, fire away, decent results.
11-07-2013, 07:55 AM   #28
maxfield_photo's Avatar
It looks like the flash and the shutter aren't in sync. Try setting your AF 360 to full power manually and see if you get a partially illuminated frame from the tail of the flash. That would indicate a sync problem, although the flash may be firing just after the shutters close, instead of just prior to them opening, in which case the test wouldn't reveal anything.
11-07-2013, 07:57 AM   #29
LR strips out most of the EXIF, and even inserts a bunch of stuff of it's own. Sometimes it may even include your editing history.
Once you download exiftool, run it from the command line with this command to get a full dump on screen of all the EXIF in a JPEG, including duplicate and unknown tags.:
Code:
To creat text file of the results, just pipe the output like so:
Code:
exiftool -a -u myimage.jpg >myimage.txt
11-07-2013, 03:05 PM   #30
Code:
Code:
ExifTool Version Number : 9.39
File Name : CJS_0125.jpg
Directory : .
File Size : 3.9 MB
File Modification Date/Time : 2013:11:07 16:37:32-05:00
File Access Date/Time : 2013:11:07 16:51:21-05:00
File Creation Date/Time : 2013:11:07 16:37:32-05:00
File Permissions : rw-rw-rw-
File Type : JPEG
MIME Type : image/jpeg
Exif Byte Order : Little-endian (Intel, II)
Make : RICOH IMAGING COMPANY, LTD.
Camera Model Name : PENTAX K-3
Orientation : Horizontal (normal)
X Resolution : 300
Y Resolution : 300
Resolution Unit : inches
Software : PENTAX K-3 Ver. 1.00
Modify Date : 2013:11:07 16:37:32
Artist :
Y Cb Cr Positioning : Co-sited
Copyright :
Exposure Time : 1/180
F Number : 2.0
Exposure Program : Manual
ISO : 200
Sensitivity Type : Standard Output Sensitivity
Standard Output Sensitivity : 200
Exif Version : 0230
Date/Time Original : 2013:11:07 16:37:32
Create Date : 2013:11:07 16:37:32
Components Configuration : Y, Cb, Cr, -
Exposure Compensation : 0
Metering Mode : Multi-segment
Flash : On, Fired
Focal Length : 43.0 mm
Pentax Version : 11.0.0.0
Pentax Model Type : 0
Pentax Model ID : K-3
Date : 2013:11:07
Time : 16:37:32
Quality : Best
Flash Mode : On, Fired; Internal
Focus Mode : AF-S
AF Point Selected : Fixed Center; 0
AF Points In Focus : Unknown (0x2000)
F Number : 2.0
ISO : 200
Auto Bracketing : 0 EV, No Extended Bracket
White Balance : Auto
Saturation : Normal
Contrast : Med High
Sharpness : Med Hard
DSP Firmware Version : 1.00.00.01
Effective LV : 8.5
Image Editing : None
Picture Mode : Flash X-Sync Speed AE; 1/3 EV steps
Drive Mode : Single-frame; No Timer; Shutter Button; Single Exposure
Color Space : sRGB
Pentax 0x003d : 8192
Lens Type : smc PENTAX-FA 43mm F1.9 Limited
Sensitivity Adjust : 0
Image Edit Count : 0
Camera Temperature : 19 C
AE Lock : Off
Noise Reduction : Off
Flash Exposure Comp : 0
Image Tone : Bright
SR Result : Not stabilized
Shake Reduction : On (7)
Shutter Count : 133
Faces Detected : 0
Face Position : 0 0
Raw Development Process : 13 (K-3)
Hue : Normal
White Balance Auto Adjustment : Off
Tungsten AWB : Subtle Correction
Dynamic Range Expansion : Off (auto)
World Time Location : Hometown
Hometown DST : No
Destination DST : No
Hometown City : New York
Destination City : New York
High/Low Key Adj : 0
Contrast Highlight : 0
Contrast Shadow : 0
Contrast Highlight/Shadow Adj : Off
Fine Sharpness : Off; Normal
High ISO Noise Reduction : Auto; Inactive
AF Adjustment : 0
Monochrome Filter Effect : None
Monochrome Toning : None
Face Detect : On (5 faces max); 0 faces detected
Face Detect Frame Size : 0 0
Pentax 0x0078 : 0 0
Shadow Correction : Auto
ISO Auto Parameters : Standard
Cross Process : Off
Distortion Correction : Off
Chromatic Aberration Correction : On
Bleach Bypass Toning : Off
Aspect Ratio : 3:2
Pentax 0x0085 : 0 0 0 0
Pentax 0x0086 : 0
Pentax 0x0092 : 0 0
Pentax 0x0093 : 0
Black Point : 0 0 1 0
White Point : 17920 8192 8192 11872
AE Exposure Time : 1/171
AE Aperture : 2.0
AE ISO : 200
AE Max Aperture : 1.9
AE Max Aperture 2 : 1.9
AE Min Aperture : 23
AE Min Exposure Time : 1/171
Auto Aperture : On
Min Aperture : 22
Lens F Stops : 8.5
Lens Kind : 0x18
LC1 : 0x94
LC2 : 0x2e
LC3 : 0x76
LC4 : 0x84
LC5 : 0x03
LC6 : 0x12
LC7 : 0x61
Focal Length : 42.5 mm
Nominal Max Aperture : 2.0
Nominal Min Aperture : 23
LC10 : 0x61
LC11 : 0x44
LC12 : 0x01
Max Aperture : 1.9
LC14 : 0x95
LC15 : 0xfb
Pentax 0x0209 : ljikossrnlllkkfa`]_][``\^`aaaab``bjtvutsspopqmkkmqstqnm[...]
Pentax 0x020a : wvtssopqqqppwwwrssttwwzz{wwwwxwx[...]
Pentax 0x020b : [...]
Manufacture Date : 2013:09:21
Production Code : 2.1
Internal Serial Number : 7005365
Power Source : Body Battery
Body Battery State : 5
Grip Battery State : 1
Pentax 0x021a : .................[...]
Saturation Info : (Binary data 364 bytes, use -b option to extract)
Pentax 0x021c : ... O..
Pentax 0x021d : 6@5*
Pentax 0x021e :
AF Points Unknown 1 : (none)
AF Points Unknown 2 : [14]
AF Predictor : 9095
AF Defocus : 2
AF Integration Time : 4 ms
AF Points In Focus : Unknown (35)
Kelvin WB Daylight : 5205 0 2.135986328125 1.3951416015625
Kelvin WB 01 : 2500 0 1.158935546875 2.51220703125
Kelvin WB 02 : 2630 0 1.2186279296875 2.4066162109375
Kelvin WB 03 : 2780 0 1.2880859375 2.2913818359375
Kelvin WB 04 : 2940 0 1.36181640625 2.1785888671875
Kelvin WB 05 : 3130 0 1.4471435546875 2.0584716796875
Kelvin WB 06 : 3330 0 1.5335693359375 1.947509765625
Kelvin WB 07 : 3570 0 1.6317138671875 1.833740234375
Kelvin WB 08 : 3850 0 1.73828125 1.7227783203125
Kelvin WB 09 : 4170 0 1.84912109375 1.618896484375
Kelvin WB 10 : 4550 0 1.9664306640625 1.5201416015625
Kelvin WB 11 : 5000 0 2.087646484375 1.428955078125
Kelvin WB 12 : 5560 0 2.215087890625 1.3424072265625
Kelvin WB 13 : 6250 0 2.3431396484375 1.263427734375
Kelvin WB 14 : 7140 0 2.4718017578125 1.1907958984375
Kelvin WB 15 : 8330 0 2.5985107421875 1.1240234375
Kelvin WB 16 : 10000 0 2.71923828125 1.0631103515625
WB Shift AB : 0
WB Shift GM : 0
EV Steps : 1/3 EV Steps
Sensitivity Steps : 1 EV Steps
Pentax 0x0227 : [...]
Pentax 0x0228 : [...]
Serial Number : 4834224
Source Directory Index : 0
Source File Index : 0
Digital Filter 01 : Off
Digital Filter 02 : Off
Digital Filter 03 : Off
Digital Filter 04 : Off
Digital Filter 05 : Off
Digital Filter 06 : Off
Digital Filter 07 : Off
Digital Filter 08 : Off
Digital Filter 09 : Off
Digital Filter 10 : Off
Digital Filter 11 : Off
Digital Filter 12 : Off
Digital Filter 13 : Off
Digital Filter 14 : Off
Digital Filter 15 : Off
Digital Filter 16 : Off
Digital Filter 17 : Off
Digital Filter 18 : Off
Digital Filter 19 : Off
Digital Filter 20 : Off
Level Orientation : Horizontal (normal)
Composition Adjust : Off
Roll Angle : 2
Pitch Angle : -25
Composition Adjust X : 0
Composition Adjust Y : 0
Composition Adjust Rotation : 0
Pentax 0x022c : .v/.$.V....ȽY..o.,..aj
Pentax 0x022d : ..F ...sT $.K t*.B) BV.1R /.E 5[...]
Contrast Detect AF Area : 0 0 0 0
Pentax 0x0234 : [...]
Pentax 0x0238 :
Pentax 0x023b : .V.._
Pentax 0x023c : [...]
Pentax 0x023d : ........
Pentax 0x023e : ....
Pentax 0x0240 : ..^?&..[...]
Pentax 0x0404 : ...... ... %..i<.n.@I[oٕuo[...]
Pentax 0x0406 : .... ... %.._Zoxzx1Dxz.x8x.x.2x^.xo[...]
Flashpix Version : 0100
Color Space : sRGB
Exif Image Width : 6016
Exif Image Height : 4000
Interoperability Index : R98 - DCF basic file (sRGB)
Interoperability Version : 0100
Sensing Method : One-chip color area
File Source : Digital Camera
Scene Type : Directly photographed
Custom Rendered : Normal
Exposure Mode : Manual
Focal Length In 35mm Format : 64 mm
Scene Capture Type : Standard
Contrast : High
Saturation : Normal
Sharpness : Hard
Subject Distance Range : Close
GPS Version ID : 2.3.0.0
PrintIM Version : 0300
Print IM 0x0001 : 0x00160016
Print IM 0x0002 : 0x00000001
Print IM 0x0003 : 0x000000d6
Print IM 0x0007 : 0x00000000
Print IM 0x0008 : 0x00000000
Print IM 0x0009 : 0x00000000
Print IM 0x000a : 0x00000000
Print IM 0x000b : 0x0000011e
Print IM 0x000c : 0x00000000
Print IM 0x000d : 0x00000000
Print IM 0x000e : 0x00000134
Print IM 0x0100 : 0x00000005
Print IM 0x0101 : 0x000000ff
Print IM 0x0102 : 0x00000083
Print IM 0x0103 : 0x00000083
Print IM 0x0104 : 0x00000083
Print IM 0x0105 : 0x00000083
Print IM 0x0106 : 0x00000083
Print IM 0x0107 : 0x00808080
Print IM 0x0110 : 0x00000080
Print IM 0x0200 : 0x00000000
Print IM 0x0207 : 0x00000000
Print IM 0x0208 : 0x00000000
Print IM 0x0209 : 0x00000000
Print IM 0x020a : 0x00000000
Print IM 0x020b : 0x00000144
Print IM 0x020d : 0x00000000
Print IM 0x0300 : 0x00000005
Print IM 0x0301 : 0x000000ff
Print IM 0x0302 : 0x00000083
Print IM 0x0303 : 0x00000083
Print IM 0x0306 : 0x00000083
Print IM 0x0310 : 0x00000080
Compression : JPEG (old-style)
X Resolution : 300
Y Resolution : 300
Thumbnail Offset : 32130
Thumbnail Length : 6133
Warning : [minor] Unknown APP7 segment
Image Width : 6016
Image Height : 4000
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Y Cb Cr Sub Sampling : YCbCr4:2:2 (2 1)
Aperture : 2.0
Image Size : 6016x4000
Lens ID : smc PENTAX-FA 43mm F1.9 Limited
Scale Factor To 35 mm Equivalent: 1.5
Shutter Speed : 1/180
Thumbnail Image : (Binary data 6133 bytes, use -b option to extract)
Circle Of Confusion : 0.020 mm
Field Of View : 31.4 deg
Focal Length : 43.0 mm (35 mm equivalent: 64.0 mm)
Hyperfocal Distance : 45.80 m
Light Value : 8.5
File Name : CJS_0086.jpg
Directory : .
File Size : 2.1 MB
File Modification Date/Time : 2013:11:06 20:16:12-05:00
File Access Date/Time : 2013:11:07 17:02:25-05:00
File Creation Date/Time : 2013:11:07 17:02:25-05:00
File Type : JPEG
X Resolution : 300
Y Resolution : 300
Modify Date : 2013:11:06 20:16:12
Artist :
Copyright :
Exposure Time : 1/100
F Number : 8.0
Exposure Program : Aperture-priority AE
ISO : 100
Standard Output Sensitivity : 100
Exif Version : 0230
Date/Time Original : 2013:11:06 20:16:12
Create Date : 2013:11:06 20:16:12
Flash : On, Fired
Date : 2013:11:06
Time : 20:16:12
Quality : Best
Flash Mode : On, Fired; External, P-TTL Auto
Focus Mode : AF-S
AF Point Selected : Auto; 0
AF Points In Focus : Left
F Number : 8.0
ISO : 100
Saturation : Normal
Contrast : Med High
Effective LV : 12.5
Picture Mode : Aperture Priority; 1/3 EV steps
Color Space : sRGB
Camera Temperature : 25 C
AE Lock : Off
Image Tone : Bright
Shutter Count : 94
Faces Detected : 0
Face Position : 0 0
Hue : Normal
Hometown DST : No
Contrast Shadow : 0
AF Adjustment : 0
Pentax 0x0078 : 0 0
Cross Process : Off
Aspect Ratio : 3:2
Pentax 0x0086 : 0
Pentax 0x0092 : 0 0
Pentax 0x0093 : 0
Black Point : 0 0 0 0
AE Exposure Time : 1/85
AE Aperture : 8.0
AE ISO : 100
Auto Aperture : On
Min Aperture : 22
Lens F Stops : 8.5
Lens Kind : 0x18
LC1 : 0x94
LC2 : 0x2e
LC3 : 0x76
LC4 : 0x84
LC5 : 0x03
LC6 : 0x12
LC7 : 0x61
LC10 : 0x61
LC11 : 0x44
LC12 : 0x01
Max Aperture : 1.9
LC14 : 0x95
LC15 : 0xfb
Pentax 0x0209 : dedccccb```beea\^acccbccb_ZW\^][ZYYYTWTTSSSTUeddbcdcca`[...]
Pentax 0x020a : [...]
Pentax 0x021e :
AF Points Unknown 1 : Top, Upper-right, Left, Mid-left, Center, Mid-right, Right, Lower-left, Bottom, Lower-right
AF Predictor : 1415
AF Defocus : 2
AF Points In Focus : Unknown (236)
WB Shift AB : 0
WB Shift GM : 0
Roll Angle : -1
Pitch Angle : 3
Pentax 0x0238 :
Pentax 0x023b : ..V..._T
Pentax 0x0240 : ..=&...x.[...]
Pentax 0x0404 : ...... .......E."[+uenkqC[...]
Pentax 0x0406 : .... .......sokyĉ~y.@yV*y<y.y9.yr yZ[...]
Color Space : sRGB
Exposure Mode : Auto
Contrast : High
Saturation : Normal
Sharpness : Hard
X Resolution : 300
Y Resolution : 300
Thumbnail Length : 3638
Image Width : 6016
Image Height : 4000
Bits Per Sample : 8
Aperture : 8.0
Shutter Speed : 1/100
Thumbnail Image : (Binary data 3638 bytes, use -b option to extract)
Hyperfocal Distance : 11.45 m
Light Value : 12.6
PENTAX K-3  Photo
PENTAX K-3  Photo
dslr, flash, k-3, k-3 flash, k3, pentax k-3, picture
WB issue in LR 5 with K-3 DNG Azzy Pentax K-3 21 12-16-2013 04:51 PM
K-5 IIs firmware 1.03 improves tilt flash overexposure issue bjdavey Pentax K-5 11 03-11-2013 10:42 AM
Pentax K-m flash issue mmand Pentax DSLR Discussion 8 01-23-2013 09:36 AM
Weird white balance issue on my K-5 with flash Codazzle Pentax K-5 3 01-02-2013 04:04 PM
K-5 and Off-camera Flash Sync Issue stevelink Pentax K-5 10 12-26-2011 05:51 PM
All times are GMT -7. The time now is 12:15 AM. | See also: NikonForums.com, part of our network of photo forums!
