Originally posted by bdery How can you set this exactly? That's what I want.
I explained it above. In the button customization, set the AF button to either AF1 or AF2 (not "Cancel AF"). Then, while recording, you can use the AF button on the back of the camera to auto focus to a new target. The usual method for auto-focusing (half-press of the shutter button) does not work while recording.
Originally posted by bdery I believe if you set the Fx button to light up the LCD, then the "no light" option is grayed and you can only set the brightness to low or high. And that option (22) answered my question partially. It claims to set the brightness of the LCD when the metering system is on, so I believe when you use the Fx the metering stops lighting up the LCD.
You are correct, when the RAW/Fx button is set to toggle the LCD illumination, then the only options in custom option 22 are low or high. The RAW/Fx button toggles the light on and off.
