11-12-2013, 07:52 AM   #1
Best SD Card for K-3
Hi Guys,
First off i'm loving my new K-3, Pentax have done such an amazing job with this camera - it was really worth the wait. I upgraded from a K-r which I've had for a few years and was dying for a professional grade DSLR - I really had hit the limits of the K-r.
Here are some shots I've taken with it so far -
https://www.facebook.com/media/set/?set=a.245345892286770.1073741854.1496962...1
https://picasaweb.google.com/114770491270272169513/201311WilfordFireworks?au...eat=directlink
I have a quick question re SD Cards - currently I have two Transcend Class 6 cards - 32gb and 16gb. I want to get some quicker ones for the K-3 as there is a noticeable delay saving images onto my current cards. I know that the K-3 supports the UHS-1 protocol so i'm currently thinking either the SanDisk 32GB Extreme Pro SD Card (SDHC) - 95MB/s Class 10 UHS or the normal SanDisk Extreme (80MB/s). Has anyone got a preference of the two?
Also run a photography business (AJC Photography) and have got quite a few weddings booked for next year so i'm thinking about getting two cards and using both slots on the K-3? That way I'll have an instant backup of the photos. Trying to decide whether 32gb will be enough or if I should go for a couple of 64gb cards but that's going to be pricey!
Any help is appreciated.
Cheers
Alex
11-12-2013, 09:03 AM   #2
Caat's Avatar
The review that's been posted by Adam looks at the effects of SD card write speed on K-3 performance. Take a look at that, it might be helpful:
Pentax K-3 Review - Performance and Burst Mode - PentaxForums.com
11-12-2013, 10:33 AM   #3
QuoteOriginally posted by sharepointalex Quote
Hi Guys,
Cheers
Alex
This card or once of its smaller/larger cousins is what I'd recommend for high-speed shooting:
SanDisk 32 GB SDHC Memory Card Extreme Pro Class SDSDXP-032G-A46
Lexar also has some nice comparable cards.
11-12-2013, 10:39 AM   #4
LaurenOE's Avatar
Very nice!
One Caveat - make sure you read the SN# carefully when ordering SD cards
Just because the picture shows a '32gb' card with one transfer rate, make sure you get the right one!
11-13-2013, 03:49 AM   #5
Enigmaticca's Avatar
I use Hoodman RAW Steel and Sandisk Extreme PRO 32gb cards. I prefer the RAW Steels as they're just as fast as the Sandisk EP (if not faster) and very tough. See: https://www.hoodmanusa.com/products.asp?dept=1013
11-13-2013, 06:11 AM   #6
bdery's Avatar
The one thing you have to look for if you want to purchase a card, regardless of the brand, is to get one with UHS-1 compatibility. That will ensure that you get the best speed possible.
The cheapest I found that appear to be any good are the microSD Sandisk UHS cards that sell with an adapter to make them regular SD. Lifetime warranty, works also in a cell phone or tablet, and about 15$ CAD for 16 GB.
11-13-2013, 08:11 AM   #7
Ahab's Avatar
I use the PNY Elite Performance 32 GB UHS-1, 90MB/s and Sandisk Extreme 32 GB UHS-1, 80MB/s. Both have the same warranty and physical specs. Both seem to offer similar speed but the PNY is less expensive.
11-13-2013, 09:15 AM   #8
Hi Guys,
https://www.facebook.com/media/set/?set=a.245345892286770.1073741854.149696268518400&type=1
Cheers
Alex
With 32GB RAW you will get almost 600 images on the cards. That should be enough, but if it isn't then you would be looking at 2 32GB and maybe adding 2 16GB for extra capacity. Or you could just go with 2 64GB and not worry about it. They question is: How many images do you take at a typical wedding? If you shoot 1000 images at a wedding then you need more capacity.
01-25-2014, 12:39 PM   #9
pete89's Avatar
Hi Guys,
Cheers
Alex
I just had to send back a Sony 64GB 94MP/sec sdxc1 card because it kept generating the error ¨card not formatted¨ and losing what photos I had on it, nothing important fortunately. It did this after reformatting several times both on the Mac and in the K3- So I´d give that one a miss anyway.
04-07-2014, 09:00 PM   #10
Pepe Guitarra's Avatar
Adam: Did you see this test?
https://www.pentaxforums.com/forums/172-pentax-k-3/249390-looking-fast-sdhc-c...i-94-mb-s.html
09-15-2015, 10:57 AM   #11
K-3 Memory Card Q&A | Ricoh Imaging Support
09-16-2015, 07:30 PM   #12
kkoether's Avatar
I've been using the 32GB Sandisk Extreme Plus cards in my K-3 for over a year now. I've been real happy with them in Burst Mode which I use a lot at the races. While the rear LCD says 600 shots when they are empty I regularly get around 1000 shots per card. They usually retail around a $1.00 per gig.
11-05-2015, 03:34 PM - 1 Like   #13
Des
Des's Avatar
Pentax K-3 II SD Card Write Speed Comparison of Fastest Memory Cards for the Pentax K3 II Digital Camera - Camera Memory Speed Comparison & Performance tests for SD and CF cards
11-06-2015, 09:33 AM   #14
ScooterMaxi Jim's Avatar
Nice link, Des. The chart confirms what Adam has long indicated - you are wasting your money buying cards that outperform the camera buffer. I did similar tests and came to the same conclusion. I went with the Sandisk Extreme Plus, but even the slower Extreme pretty much matches that (I'm not sure if the Extreme can handle full HD video without a glitch, though). It looks like the Lexar 600x 64gb at $25 is a great deal now.
One supreme rule separates professional work from all else. A pro always has a back up plan - and that is a cardinal rule for weddings, obviously. You absolutely must have a duplicate card on stand by (or even two extras - they're so cheap). I'd sacrifice performance or prestige to make sure you are covered in case of possible card failure.
11-06-2015, 10:54 AM   #15
pete-tarmigan's Avatar
QuoteOriginally posted by ScooterMaxi Jim Quote
I overheard the owner of one of our local camera stores saying that he thinks that memory cards are so cheap and that hard drives and writeable CDs/DVDs so unreliable that every time he fills a card he buys new card. In other words, SD cards alone are his long-term storage strategy. I don't think I could afford to buy new Sandisk Extreme cards every time I filled cards.
32gb, backup, camera stores, card, cards, class, dslr, k-3, k-r, k3, memory cards, money, pentax k-3, photography, sandisk, sd, sd card, time
Which SD card type is best used for the Q? kyuuan Pentax Q 27 11-08-2012 12:33 AM
Best SD card for RAW shooting cwebsterlusk Pentax DSLR Discussion 9 11-06-2011 11:39 PM
Best SD card and reader for my new K-7? Loren E Troubleshooting and Beginner Help 3 10-19-2010 03:08 PM
Best SD card speed for K-7? schmik Pentax DSLR Discussion 16 08-12-2009 07:42 PM
Best SD card for me? Buschmaster Pentax DSLR Discussion 3 12-15-2006 11:05 AM
All times are GMT -7. The time now is 01:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
