11-16-2013, 03:03 PM   #16
QuoteOriginally posted by BeetleStuff Quote
I picked up my K3 and have noticed that when using a weather resistant zoom lens (DA 18-135mm WR) it produces a very audible hiss from escaping air around the rear e-dial on the camera body when zooming back rapidly.
I understand that air needs to flow for this type of lens, but the thing that disturbs me is that my K5 using the same lens has no air exiting around the rear e-dial, just a small puff around the viewfinder.
In comparison my K3 has a very strong loud flow of air from around the rear e-dial as well as a small puff around the viewfinder. I can also hear the air exhaust holding the camera at arm’s length.
Probably just a different design but I am worried that it has a faulty seal and would appreciate some help with a comparison to other people’s K3 cameras.
Can someone with a DA 18-135mm WR zoom on the K3 camera extend the zoom fully, then put your ear directly over the rear e-dial on the camera body and then zoom back rapidly – Does anyone else get a loud hiss from around the rear camera body e-dial?
Thanks.
Just tried your set-up on my new K3. There was zilch sound from anywhere on the camera after 3-4 zoom rotations
11-17-2013, 03:01 AM   #17
BeetleStuff's Avatar
QuoteOriginally posted by asahi67 Quote
Thanks for the feedback, it is appreciated.
As lister6520 pointed out the air that needs to escape may be exiting through a tighter than normal orifice on my K3 producing a hiss under pressure.
This explanation turned my thoughts around from a return to keeping it as everything else works properly and the lenses that I have used with it so far appear to be spot on with regard to AF.
Regards Rob.
air, body, camera, comparison, dslr, e-dial, k-3, k3, lens, pentax k-3, puff, viewfinder
Amateur Photographer UK says Pentax K3 is a giant step for Pentax raider Pentax K-3 9 10-29-2013 03:18 PM
K3 is listed by ricoh/pentax WPRESTO Pentax News and Rumors 7 10-07-2013 06:27 AM
K5 video hissing sound Casabob Pentax K-5 3 09-12-2013 02:55 AM
My Pentax K-5 is scaring me! (HELP!) Pentaxguy22 Pentax K-5 5 06-06-2013 05:29 AM
Is the Pixel war over -With the D4 at 16M, why does the K3 need to go to 24? philbaum Pentax DSLR Discussion 72 05-22-2012 03:23 PM
All times are GMT -7. The time now is 05:05 PM. | See also: NikonForums.com, part of our network of photo forums!
