Originally posted by OregonJim curious is that I purchased this less than a month ago from B&H, a full 5 months after the alleged "manufacture date"...
It appears that photography retailers don't turn over their inventory very fast. Then there is the supply pipeline from manufacturer to distributor and then to retailer. My local retailer has a few bodies and lens celebrating birthdays.
Originally posted by OregonJim Could it be the second major rev of the board?
Maybe, maybe not. My K-30 was manufactured 6/17/2012 right about when it was announced, and it has 2.2 for a production code. The timeline from when a new component is released for production to bad experiences with it in the field from end users, to getting engineering to re-design the component and release the revision to manufacturing will require several months, if not years. Now if the plant discovers a problem with the design, which will only be related to glitches in the manufacturing process or a series of catastrophic failures at the final QA stage, then engineering will have to redesign the problem component ASAP or else costs will mushroom. There is no way a subtle problem like this will be caught by manufacturing, so even if your K-3 has updated components in it, those changes didn't "fix" the shutter delay for your camera.
