07-11-2017, 04:17 AM   #301
JimJohnson's Avatar
Location: Summer:Lake Superior - Michigan Winter:Texas Hill Country
Since we are grousing with little expectation of change - as far as I am concerned, TTL - not pTTL - flash was the best flash control produced by Pentax. Second best is autothyristor controlled flash with the sensor built into the flash.
Sure I am giving up optical wireless control but radio flash controls are a reliable alternative.
10-02-2017, 05:50 AM   #302
TER-OR's Avatar
I just started experiencing this delay after 2 years of using the K3II. It happens with a Sunpak manual ring flash in Manual mode. Since I mostly do outdoor macro work, this is a serious problem. I simply can't tolerate a half-second delay. I'll go through the settings again, make sure nothing has changed but needless to say I'm not amused.
Again, for 2 years there was never a delay using flash in manual or automatic modes.
10-02-2017, 10:53 AM   #303
Otis Memorial Pentaxian
QuoteOriginally posted by TER-OR Quote
That is strange. My understanding is that the delay is limited to P-TTL flash. With a non-dedicated flash mounted, the camera should be "unaware" that flash is being used. Do you have delay with non-flash usage?
10-02-2017, 01:57 PM   #304
TER-OR's Avatar
Nope, even if the flash is mounted and not powered on, no delay.
I'm going to check the flash settings, make absolutely sure it's in manual mode.
10-02-2017, 02:05 PM   #305
enoeske's Avatar
manual mode flash setting on the camera only refers to the pop-up flash. You have to have the external flash set to manual mode.
10-02-2017, 06:26 PM - 1 Like   #306
TER-OR's Avatar
Yeah, my verbiage was imprecise.
Anyway - I reset the camera settings and it's all cleared up! I have no clue what the setting was, but the reset took care of it.
dslr, flash, issue, k-3, k3, moment, p-ttl, pentax k-3, people, technology
Need to disable in-built flash when using off camera flash Molly Flashes, Lighting, and Studio 18 03-27-2013 04:12 AM
Adobe or Embedded when using the k5 in Lightroom 3.6 ? London Rob Digital Processing, Software, and Printing 2 11-21-2012 12:58 PM
How does the camera meter when using an external flash? jpeldrid Flashes, Lighting, and Studio 7 12-04-2011 09:27 AM
k-7 + 3 sec delay = no flash slave. Anyone know why? Nass Pentax DSLR Discussion 5 03-16-2010 09:57 AM
Closed eyes when using the flash xfraser Flashes, Lighting, and Studio 5 01-31-2007 12:52 PM
All times are GMT -7. The time now is 12:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
