02-03-2014, 08:32 AM   #91
Tjompen1968's Avatar
QuoteOriginally posted by gosman Quote
Just tried my on board flash again. Shot about 5 times -no hesitation. This seems to be a non issue with maybe a few early models exhibiting the delay.
If you compare using thé two flash modes, P-TTL mode and M mode you have no difference in respons?
02-03-2014, 09:08 AM   #92
I actually have a slight delay when in flash manual mode . But I do not have a delay in P-TTL!! Is this what is happening to others?
02-03-2014, 09:49 AM   #93
RGlasel's Avatar
Perhaps the camera is waiting for the auto-focus to complete. The delay between P-TTL pre-flash and the firing of the flash is brief, a fraction of a second, and I believe you can set your camera so the shutter opens immediately when you trigger it instead for waiting for the camera's auto-focus. The only other thing I can think of that will cause a delay is setting your flash for red eye reduction.
02-03-2014, 02:34 PM   #94
Reasonable assumption. The OP should put the camera in manual focus mode then retry the experiment to see if the delay is gone.
Jack
02-03-2014, 05:00 PM   #95
bxf
bxf's Avatar
I assume the K-3 has something like the K-5 "Link exposure to AF point", or something like that. I know this is a shot in the dark, but has anyone tried to see if this setting is a factor in the delay? Just a thought, because at least one poster says he does not experience the delay.a
02-03-2014, 06:02 PM   #96
jup
QuoteOriginally posted by jbinpg Quote
Jack
This has been tried before and suggested to me by Pentax support. No effect whatsoever.
QuoteOriginally posted by bxf Quote
Interesting idea. But also no effect. I am still yet to find any combination of settings that would work.
BTW, I bought camera 2 weeks ago from B&H. Although it has been manufactured in October, I wouldn't assume it's early models. But if some people experience it and others don't, hardware may be to blame.
02-03-2014, 06:45 PM   #97
enoeske's Avatar
K-3 Silver here with the delay as well. Its small but noticeable between pressing the shutter and pre-flash
02-03-2014, 07:44 PM   #98
RGlasel's Avatar
QuoteOriginally posted by enoeske Quote
Not firing the flash until the lens is focused is a feature, not a bug. I don't know what the standard delay for P-TTL communication is, but with strobe flashes, very short (fractions of a second) gaps between light flashes are perceptible. As long as the flash and the shutter are synced, and your subject doesn't fall over in the meantime, a one or two second delay shouldn't be a problem.
02-03-2014, 08:08 PM   #99
enoeske's Avatar
QuoteOriginally posted by RGlasel Quote
Camera is pre-focused using the rear AF button. After focus is confirmed, shutter is depressed. There is a noticeable delay before the pre-flash begins. This did not occur with any previous Pentax DSLR.
Are you insane? That would be a huge problem.
02-03-2014, 08:44 PM   #100
jup
Yeah. Luckily delay is really relatively brief - was just playing with flash in downtown San Francisco yesterday, taking photos of moving cars in the night with trailing curtain sync and it still worked relatively well, but the delay is there even with trailing curtain sync and long shutter - before the preflash. Now, with 2s delay... The car would have been kind of gone by that time.
02-03-2014, 09:01 PM   #101
RGlasel's Avatar
I have no idea what kind of flash pictures you are taking, but as long as the flash fires while the shutter is open, I can't imagine what your problem is. Could there be a problem with your camera? Perhaps, but the hand isn't quicker than the eye (or the camera), and if you need to capture the instant an event occurs, you need to look at a different method of triggering your flash than one press of your finger, and that method won't work with P-TTL. Sorry.
02-03-2014, 11:01 PM   #102
build date
QuoteOriginally posted by jup Quote
How do you know your camera was built in October? How can I find out about mine?
02-04-2014, 01:24 AM   #103
jup
It's in the EXIF. If your viewer doesn't show it, just use Adam's excellent online tool: Check Shutter Count & Camera Manufacture Date Online - EXIF Reader
02-04-2014, 01:51 AM   #104
awaldram's Avatar
Let me give you an example were the additional 1/10 delay is disastrous
Taking a picture of a professional fly swimmer I line up the shot as the swimmer surfaces focused ready to shoot press the shutter ......... swimmer disappears under water flash fires
I can only assume you have little experience of flash or P-ttl and shoot nothing but static subjects as even 'chasing kids' would be frustrating with this delay.
As the delay is not part of P-ttl and is introduced with the k3 it can only a bug.
02-04-2014, 07:20 AM   #105
Thank you Jup for the manufacturing date info. The site was very beneficial. My camera was manufactured on 10-13-1013. Does anyone know when the first date is of manufacture? Anyone getting more recent cameras? Maybe I should start a different thread? I did have a complete shut down of the camera yesterday. I updated last night to the 1.01 firmware upgrade. I don't like getting one of the first cameras off the line. But I guess that is what upgraded firmware is all about.
dslr, flash, issue, k-3, k3, moment, p-ttl, pentax k-3, people, technology
Need to disable in-built flash when using off camera flash Molly Flashes, Lighting, and Studio 18 03-27-2013 04:12 AM
Adobe or Embedded when using the k5 in Lightroom 3.6 ? London Rob Digital Processing, Software, and Printing 2 11-21-2012 12:58 PM
How does the camera meter when using an external flash? jpeldrid Flashes, Lighting, and Studio 7 12-04-2011 09:27 AM
k-7 + 3 sec delay = no flash slave. Anyone know why? Nass Pentax DSLR Discussion 5 03-16-2010 09:57 AM
Closed eyes when using the flash xfraser Flashes, Lighting, and Studio 5 01-31-2007 12:52 PM
All times are GMT -7. The time now is 08:39 AM. | See also: NikonForums.com, part of our network of photo forums!
