01-09-2014, 06:30 PM   #31
QuoteOriginally posted by grahame Quote
Tak 300/3.5 is a preset lens. There is nothing on the read end controls aperture. The 2nd ring on the front does that. Pushing green button won't do anything to the exposure metering or aperture stop down. Camera meters before you press the shutter button.
Correct, I misspoke! I meant metering with the green button using a M42 lens. Not stopping down as I indicated...sorry. Also, I was using a 200/3.5
01-09-2014, 06:36 PM   #32
This (no Green Button metering in LiveView for Takumar lenses) is a well-documented condition, begining with the K-01. It has to do with the paint on the Takumar lens mount failing to short the contacts on the camera. There are kludge work arounds such as using bits of foil stick to the lens - apparently Pentax is in no hurry to correct this in a FW update.
Bayonet mount lenses do not exhibit this behavior, presumably because the mounts are not painted.
Getting back to the original topic (sort of, since I can only comment on the K-01), just repeating that my K-01 green button sets the shutter speed just fine with m42 lenses (or even no lens at all) in M mode. (ISO must be fixed.)
camera, contacts, dslr, k-3, k3, meter, pentax k-3, view
stop-down metering with MX Alx Film SLRs and Compact Film Cameras 11 08-18-2023 06:53 AM
No stop down metering with pentax-m lenses (K-x) Aeldrhamir Pentax DSLR Discussion 10 01-23-2013 09:49 PM
K-X stop down metering problems with fast lenses i_trax Pentax DSLR Discussion 3 07-27-2011 06:00 AM
Stop Down metering with K-5 jva59 Pentax K-5 & K-5 II 8 03-29-2011 06:43 AM
K-x Stop-down metering with m-42 lenses Bazwell Pentax DSLR Discussion 8 11-20-2009 12:57 PM
All times are GMT -7. The time now is 10:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
