11-17-2013, 04:31 AM   #1
Auto EV compensation setting
I came across this setting in the menus. As I half expected the manual is of no help as it just says the same that the camera already told me.
Searching around the forum I found this thread relating to this feature on earlier cameras:
https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/162938-auto-ev-compensation.html
I don't see this feature on my K-r and K-30 and thought it was something new on the K-3 but the above thread shows it has existed in the past and seems to have been revived.
It seems to be meant to prevent overexposure by over-riding what it would consider incorrect settings and may be helpful if well designed and thought out. Mostly for when I absent mindedly ignore the flashing over/under exposure warning in the viewfinder, something which happens to me a lot more often than it should.
I've tried what was suggested in the K10/K20 thread on the subject and can see similarities in the behaviour.
Has anyone used this feature on the K-3 and/or experience with it on other cameras?
The 86K exposure sensor opens up many new possibilities and I can see some ways it could make this feature much more useful than it could have been on older cameras.
11-17-2013, 05:01 AM   #2
Col
Col's Avatar
It's quite simple:
on- the camera will still override the parameters set by you should it measure that the exposure will be off
Off- you'll get what you get.
Generally I have it on. But off for specific user modes ie. Bird in flight...don't want the camera adjusting spot meter
cameras, dslr, exposure, feature, k-3, k3, pentax k-3, thread
EV compensation no694terry Pentax K-5 17 04-29-2013 09:10 AM
ev compensation lguckert79 Troubleshooting and Beginner Help 4 01-17-2012 08:36 PM
Auto EV Compensation Billgscott Pentax DSLR Discussion 7 10-26-2011 11:07 AM
Auto EV Compensation Workingdog Pentax DSLR Discussion 18 09-17-2008 08:25 PM
Why does ev compensation set off auto iso? jake123 Pentax DSLR Discussion 12 02-29-2008 07:29 AM
All times are GMT -7. The time now is 10:55 AM. | See also: NikonForums.com, part of our network of photo forums!
