11-18-2013, 07:11 AM   #1
K3 cancel AF and Continuous shooting problem
My K3 will only take a single shot if using the AF button to cancel the AF in AF.C mode even though I have the K3 set to Continuous Shooting (High), anyone else have this problem.
This doesn't happen with my K5.
11-18-2013, 07:28 AM   #2
Unregistered User
Guest
Same on mine. Tested different settings in the C-menu but the same result. If I set Manual fokus it starts snapping again. I dont use it like that but so you know it is the same on my unit.
11-18-2013, 07:31 AM   #3
Banned
I love to see the next firmware update with Overal stability improvement!
11-18-2013, 07:35 AM   #4
QuoteOriginally posted by Tjompen1968 Quote
OK that's three people with K3s that confirm this problem, sounds like a firmware problem.
11-18-2013, 07:45 AM   #5
Otis Memorial Pentaxian
now that you mention it mine does too but only had it at medium setting...i haven't tried it at any other settings
11-18-2013, 07:50 AM   #6
QuoteOriginally posted by mille19 Quote
Do you have enabled fps priority or focus priority for first and other shots in custom functions?
11-18-2013, 08:07 AM   #7
QuoteOriginally posted by fyby Quote
Focus priority for first shot, fps priority for shots after
11-18-2013, 08:42 AM   #8
Then it should work, IMHO.
11-18-2013, 09:07 AM   #9
I know, it works on my K5 OK, like I said I think it's a firmware glitch
11-18-2013, 10:48 AM   #10
VisualDarkness's Avatar
That's a serious glitch and a nightmare for sports shooters.
02-15-2014, 10:14 AM   #11
photoephemere's Avatar
Keep calm ... ;-)
There's absolutely no bug and trouble with af off using rear af button when continous shooting and constant af ... Just put these setting to your camera :
- C3-16 : 2 or wathever you want ...
- C3-17 : 3 or another setting ...
AND !
C4-25 : 1 - OFFFFF !!!
And it will work great ;-)
It's so logical ... No need for ré-engeeniring... ;-)
02-15-2014, 11:27 AM   #12
Unregistered User
Guest
QuoteOriginally posted by photoephemere Quote
Keep calm ... ;-)
AND !
EDIT: The C4-25 Off = Working
02-15-2014, 11:32 AM   #13
there was no problem, just c4-25 reseted by F upgrade. Try with last Firmware this set activating C4-25 and you ll see ...
Seems only a bad user setting... ? Not ?
02-15-2014, 04:42 PM   #14
Unregistered User
Guest
I have the 25 set to On...
EDIT: No, it is set to off... My bad.
02-15-2014, 05:08 PM   #15
jup
Mine behaves the same with 1.02.
Still looks like a bug to me, but with C 25->off it works.
With C25->on it's just weird. It will take single shot but as long as you hold shutter button, you can hear sensor stabilization going on. It's just not taking any pictures!
af, dslr, k-3, k3, pentax k-3
K3. AF working and continuous shooting speed ArsenAl Pentax K-3 & K-3 II 2 11-13-2013 11:22 PM
K-7 continuous shooting problem silverbow47 Troubleshooting and Beginner Help 3 01-23-2012 03:57 PM
K-7 continuous shooting problem Rusty Rat Pentax DSLR Discussion 9 04-25-2010 08:11 AM
K-x continuous shooting problem. JP_Seattle Pentax DSLR Discussion 10 01-20-2010 11:23 AM
K10D Continuous Shooting problem emo gootch Pentax DSLR Discussion 15 09-28-2009 10:47 AM
All times are GMT -7. The time now is 07:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
