Originally posted by Alcazar If i understood right, the 4-way-controller is used to access white balance and stuff, but when i press the focus point selection button first, it's used for focus point selection. - Is that a toggle (so once the focus point selection button has been pressed, i am in focus point selection mode forever, or maybe until power off) or do i have to do it everytime i want to change the focus point? - Is there an option to always and forever reverse this behaviour (no button press -> change focus points, button press -> access white balance)?
Yes, it's a toggle, and no, you can't change the way it works. It's annoying because if you disable the status screen, you have no way of knowing which mode the camera is in without trial and error when away from the viewfinder.
Originally posted by Alcazar I remember there was an issue with the K5 that after long exposures there was a dark frame substraction that you could not deactivate. I don't know if they changed that later... anyway: - Does the K-3 do that? - Is there an option to turn it off? - Is it actually necessary with the K-3 (i always wondered if these hot pixels were just a flaw of the K5 or if that happens with every sensor when doing long exposures)?
Yes, you can turn it off (there's a setting in the info screen). I would advise keeping it on for very long exposures (say a 3 minutes or longer). For anything shorter than that you can safely leave it off and let pixel mapping / your raw file take care of the hot pixels, if any.
Originally posted by Alcazar My K10D zooms in a wierd way: instead of zooming in 25%, 50%, 100% like you do in photoshop, it zooms in 2x, 4x, 8x magnification of the screen size... with roughly 6.4x giving you a 100% zoom which you can't really select so you never can see 1 Pixel in the image being 1 Pixel on the screen... - Does the K-3 zoom in the same way? - In magnifications over 100%, does the K-3 blur the pixels? - Is there focus peaking in playback mode? I mean it would be nice to quickly check if i nailed the focus after i took a picture, without having to zoom in
There is now a 100% zoom mode in addition to the others, which works out to be 8.3x zoom. Overzoom will blur the image (by definition), and no, there is no focus peaking.
Originally posted by Alcazar On my K10D, long exposures over 30 seconds had to be done manually... by holding the button on the remote for as long as you wanted the exposure to be, and looking at your stopwatch at the same time :-) - Can i just dial in say 8m37s, and the K-3 does a long exposure of that length? My tired fingers would be thankful
You can't dial it in, but if I'm not mistaken, you can press the shutter button to start and again to stop. This might require a remote though, I'm not 100% sure.
Some people use interval shooting as hack to easily obtain longer exposures. Whatever floats your boat - I prefer just using the remote and waiting it out
Having 2+ bodies for a night shoot helps.
PentaxForums.com Webmaster (
Site Usage Guide |
Site Help |
My Photography)
PentaxForums.com server and development costs are user-supported. You can help cover these costs by
donating or purchasing one of our
Pentax eBooks. Or, buy your photo gear from our affiliates,
Adorama,
B&H Photo,
KEH, or
Topaz Labs, and get
FREE Marketplace access - click here to see how! Trusted Pentax retailers:
