Ok, I suspect this is all somewhere in other posts but I haven't found it yet.
Is the body of the K3 close enough to the K5 that I can use my RRS (Arca) quick release plate with anti-twist lip, and L-bracket? Or will I need a new (expensive) one?
Batteries - I have several extra. Are K3 batteries the same?
Grip. I see references to a new grip. Does that mean the grip I used for the K7 and K5 won't fit the K3?
Are there features or controls on the K3 that have changed significantly from the K5? Do you like the new or old ones better?
I haven't quite decided to pull the trigger yet but am getting closer.
