Originally posted by zosxavius
It works on af1 but not af2. On the k5 both worked.
I just checked on my k-5IIs, there are two settings..
-AF (enable or disable)
-Half-press shutter (AF or Off)
So, in k-3,
AF1- means AF enabled and Half-press shutter AF
AF2- means AF enabled and Half-press shutter Off
CIF works on AF1 and not AF2
same for k-5IIs (does not work if AF enabled and Half-press shutter Off)
(note: I have not tried my k-5 yet)...
AF2 works by design if you use MF lenses and using the PDAF system; press AF button while turning the focus ring until green hexagon appears then recompose slightly, hit the shutter.
