01-18-2014, 05:46 PM   #61
Is the OP still around? I would guess he decided that the K3 doesn't have enough pop and stuck with what he had. I find that the K3 has plenty of pop as long as you pair it with good glass. Hand holding is fine with SR, although when I'm shooting landscapes, I use a tripod.
01-18-2014, 06:21 PM   #62
dadipentak's Avatar
Um...wow, Rondec!
When I bought my K-5IIs, it became clear to me that the images it produced had different qualities than those from the K-5 and I would need to tweak my routine when processing them. I'd be surprised if that weren't the case with the K-3. As I've read the K-3 commentary, I'm coming to think that, when I get one, I'm going to prefer the K-5 for some situations (where noise will be a significant issue) and the K-3 for others (where I'll need to crop a lot.) I'm basically fine with that--except that I expect I'll fumble and swear at the difference between the interfaces.
01-18-2014, 07:17 PM   #63
QuoteOriginally posted by dadipentak Quote
Um...wow, Rondec!
Thanks.
I would think a lot of your routines for the K5 IIs would work for the K3. The biggest thing about the K3 (coming from a regular K5) is that it doesn't need much sharpening and if I sharpened it to K5 levels, I got a lot of artifacts.
01-18-2014, 08:20 PM   #64
MJSfoto1956's Avatar
Of course, some of us don't go for "pop", especially with the winter weather offering us a lovely muted palette.
Here's one I did with a K-3 + DA* 60-260mm, definitely no pop here:
Cheers,
Michael
01-19-2014, 09:26 AM   #65
dadipentak's Avatar
QuoteOriginally posted by MJSfoto1956 Quote
Nice example.
01-19-2014, 09:45 AM   #66
normhead's Avatar
Thanks.
I'd agree with that as well. I'm turning my K-5 sharpening levels down or sometimes even off completely.
01-19-2014, 11:36 AM   #67
is this wow??
PENTAX K-3  Photo
01-19-2014, 01:18 PM   #68
What does WOW mean? When I first got my K5IIs over 1 year ago, I noticed that the colours seemed more muted than the K5, K30 or K01. However, in PP this can be set as desired. The K3 images can be set to whatever look you desire. I must admit that nothing compares to the K5IIs sharpness at 100%,
Dale
dslr, factor, images, k-3, k-3 images, k-5iis, k3, pentax k-3, time
Sports Images with the K-3 RonHendriks1966 Pentax K-3 365 06-18-2017 07:24 AM
The K-3 -APS-c and cropped wildlife images normhead Pentax K-3 39 10-16-2013 10:57 AM
Pentax DA 17-70 f4 - wow - images philbaum Pentax SLR Lens Discussion 9 07-18-2012 12:02 AM
K-5... Wow wow wow wow wow!! Hugely impressive. 65535 Pentax K-5 85 11-08-2010 08:45 PM
Wow...Huge difference in K10D images Darius4522 Pentax DSLR Discussion 48 10-15-2007 09:48 PM
All times are GMT -7. The time now is 02:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
