11-26-2013, 12:06 PM   #1
Shanti's Avatar
DA 300 AF speed K3 vs K5II
Hi any tests if the K3 has a faster AF or cont. AF with the DA*300 lens..this is for birding work....
Thanks S
11-26-2013, 12:10 PM   #2
QuoteOriginally posted by Shanti Quote
Thanks S
The base AF speed is the same, but for tracking the K-3 is better. It's evolution rather than revolution, though.
11-26-2013, 03:30 PM   #3
I read somewhere recently - I think it was here - that someone was getting significantly better focusing results with the K-3 - possibly because of the tracking. I can't vouch for this myself because I've stayed with my K-5 IIs for this sports season (and I'm not doing birding).
IIRC someone did much better using the DA*300 vs. e.g. the Sigma 50-500.
11-26-2013, 07:29 PM   #4
It isn't faster, the movement is the same speed. It is a more positive action. Nothing slows a lens down more than hunting for focus. On the K-5 it was always a chore to focus this lens, in my experience at least. Far different with the K-3.
The only time I've noticed the speed of the focus is when close in. For example, there were a bunch of small birds in the trees, from 6 feet to 20 feet away. That focus throw seemed slow. But further out it has less movement to make to cover distance, and it is plenty fast.
11-26-2013, 07:56 PM   #5
The time to focus for the DA*300 is the same for both the K3 and K5IIs. However, once focus is achieved the K3 can track better and feels much more confident in focussing. The extra focus points allow more refined focus locations which are an important thing for wildlife photos.
Dale
11-26-2013, 09:22 PM   #6
Shanti's Avatar
QuoteOriginally posted by DDoram Quote
Dale
how many points do you use when you focus? I normally use only the center,maybe that's why the K5II hunts a bit at long distances? many times I find it better to use MF with birds & open skies
11-27-2013, 11:34 AM   #7
Hi Shanti:
I have been using 9 point expanded most of the time but have not had time to try all of the AF combinations to really understand which will work best under a particular situation. Since the K3 AF options are greater than previous models it will take a while to figure this out. i have found though that I can focus moe closely on a subject due to having more focus points compared to the K5IIs.
Dale
01-05-2014, 11:03 AM   #8
Tord's Avatar
The focus hunting issue was one of the things that made me give up on Pentax — glad to hear that it has improved a lot — changing to Nikon turned the kettle around, so now maybe 10% is unfocused and the hunting is almost nil. How much this has to do with change of sensor size!
af, af speed k3, da 300 af, da*300, dslr, k-3, k3, k3 vs, k5ii, pentax k-3
Autofocus accuracy - K3 vs K5II vs K5 ? vrphoto Pentax K-3 57 03-19-2014 08:23 AM
K3. AF working and continuous shooting speed ArsenAl Pentax K-3 2 11-13-2013 11:22 PM
New K3 vs K5ii high iso RAW tests ihasa Pentax K-3 8 11-04-2013 09:15 AM
K-01 AF speed with DA* 300 David07 Pentax K-01 6 12-04-2012 10:58 AM
AF speed: DA 40mm Limited vs DA 18-135 mm? olenl Pentax SLR Lens Discussion 4 01-14-2011 09:35 AM
All times are GMT -7. The time now is 04:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
