Originally posted by Luschnig I've been a professional photographer for a long time and unlike Ed I shoot mainly hand held. I've come to accept a certain number shaky frames. Some, like Ed's barn, are mysterious but many are not. Two culprits for me are caffeine and cold often when coupled with any lens with "tele" in its name. A long time ago a photo writer called Rothschild claimed hand holding could only be done with near 100 per cent success at three times the focal length if all other conditions were favorable. Ed's barn test certainly met the minimum requirements of Rothschild's shutter speed criterion. But then why the small but persistent differencea between sharpness delivered by the two bodies? It is my feeling that the answer to the blurry barn phenomenon, if one is ever found, is going to lie in something simple rather than complex, something that will produce a palm to the forehead reaction rather than an intellectually befuddled stare. Once I did a shoot on a remote Greek island and when I got back to Athens and developed the film only to find it blank. I swore and worried loudly over my Leica when my non-photographic wife asked about the lens cap. That's why I bought my first Pentax SLR. Because sometimes the problems are simple and the solutions even simpler.
Now that is a professional comment!
And guess what, exactly right. The Sony sensor in the K-3 is the same one as in the A77 and the A77 was a noise monster with a very aggressive High ISO noise reduction. The K-3 High ISO Noise reduction is very aggressive as well and this is much different than the traditional conservative approach Pentax-before-Ricoh took. The default setting is High ISO Noise reduction set to Auto, and in flat light at ISO's as low as 400 it will BLOW your image sharpness to bits. Turn OFF AUTO high iso noise reduction and everything is tack sharp if you get all the other parts right. PROBLEM SOLVED. The K-3 is AWESOME. And I don't think the K-3 is a noise monster like the A77 either, so maybe Pentax/Ricoh did better than Sony on that front. but the Hi ISO Noise reduction is something to control for sure.
