Originally posted by mattipuh Is there real life difference in AF and Metering btw K3 and K5IIs?
Yep. The K-3 is better in both cases, although for AF it's highly dependant on the lens (and with SDM it's less obvious). Metering is improved, especially with PTTL. Auto WB with multizone is also very effective.
Regarding noise, a lot of things have been said, many of them innacurate. It boils down to this : per pixel, at full resolution, in the same conditions, the K-5 will be slightly better. Because its pixels are larger. It,s physics. For for the whole image (whether you see it on screen or print your image) the K-3 will deliver better results.
Long story short, I can shoot at ISO 5000 without second thoughts.
