11-29-2013, 06:34 PM   #1
zantaphia's Avatar
K-3 and wireless flash trigger?
Hi.
My wireless flash trigger works om my K-5, but not on my K-3.... i tried all? possible flash settings in the camera, but it just won't work.
Does anyone know how to do wireless flash trigger in the hotshoe of K-3?
My workaround now is to use the K-3 pop-up flash in manual mode 1/32 and thus trigger my studio flashes.
/zantaphia
11-29-2013, 07:24 PM   #2
QuoteOriginally posted by zantaphia Quote
What brand and model is it?
11-29-2013, 07:28 PM   #3
zantaphia's Avatar
It's a Cononmark 3G.
11-29-2013, 08:10 PM   #4
jatrax's Avatar
My Cactus v5 works just like on the K-5.
Try it in x-sync mode to test. I did notice the K-3 hot shoe was little tight and I had to push a little harder to get the trigger seated all the way forward.
11-29-2013, 08:18 PM   #5
Did you set the mode dial to X?
Can you connect a PC cable between camera and trigger?
11-29-2013, 09:02 PM   #6
Hi.
/zantaphia
The K-3 has a master and controller mode for wireless trigger using the pop up flash. Not sure if that is what you want.
11-30-2013, 12:15 AM   #7
zantaphia's Avatar
Thanks!
I slap my forehead.
Note to myself: Shutter time 1/200 s doesn't work for this flash setup. 1/160 s worked fine. :-)
11-30-2013, 12:22 AM   #8
philbaum's Avatar
Thanks!
I slap my forehead.
Depending on whether you specify 1/3 ev steps or 1/2 ev steps, you can also dial in 1/180 and it will work fine also.
Last summer i was shooting a portrait with flash, and couldn't get it to work, until i figured out i was over 1/180s - just like you. Sony has a better system for their nex, it doesn't let you dial in anything over the sync speed, thus avoiding a bunch of confusion.
11-30-2013, 08:36 AM   #9
You'd think Pentax would have let us shoot over the 1/180 limit by now :-P
They just need an option in the menu to enable this and when it's enabled, it'll warn you that it might cause black bars over 1/180...I don't understand why this is so hard to do??? :-P
11-30-2013, 09:30 AM   #10
QuoteOriginally posted by kenyee Quote
Offer P-ttl code to pw and china trigger company...
12-01-2013, 06:37 PM   #11
QuoteOriginally posted by mactrash Quote
Actually, I'm not talking about pTTL.
The strobe "fire" signal in x-sync should not be disabled just because it's over 1/180...look at Canikon to see how they don't disable this and Olympus doesn't either.
12-02-2013, 10:23 AM   #12
I know what you mean... I use OM fire studio flash in 1/500 etc.
12-02-2013, 12:03 PM   #13
I went through a number of usage scenarios in my head and could only come up with a couple where a flash exposure for only a partial slit of the frame would be desirable. I know the case for high sync speed, but just allowing the flash to fire to sync with a focal plane shutter at all speeds does not satisfy those.
Can you enlighten me?
(With TTL or PTTL with the flash being controlled by the camera, it is possible to do multiple bursts per exposure to allow for higher sync. I don't believe that is the case here.)
12-02-2013, 03:35 PM   #14
The only use case is outdoors in daylight when you want to lower the ambient so your speedlight is more useful...it's a workaround to avoid the requirement to use pTTL.
Read these two articles:
Strobist: Hacking Your Camera's Sync Speed, Pt 1
Strobist: Hacking Your Camera's Sync Speed, Pt. 2
I can understand Pentax wanting to avoid the user complaints of "hey, my frame has a dark band...my camera must be broken", but don't understand why it can't be a menu option for those of us who want to use this workaround when you can do it in competitor's systems
12-02-2013, 05:10 PM   #15
jatrax's Avatar
Not that it is something I would use, but I agree. They have a menu item to enable using the aperture ring on legacy lenses. I'm guessing the number of people using that would not be hugely different than those looking for faster flash sync.
dslr, flash, k-3, k3, pentax k-3
Wireless Trigger & Flash set up alamo5000 Flashes, Lighting, and Studio 29 10-03-2013 07:04 PM
flash cable or wireless trigger carlosodze Flashes, Lighting, and Studio 8 07-25-2013 06:19 PM
Need a wireless shutter and flash trigger recommendation Divers Troubleshooting and Beginner Help 8 07-17-2013 04:39 AM
For Sale - Sold: Pentax AF 360 FGZ flash + Cowboy Studio FM wireless trigger and receiver, $135 grahame Sold Items 3 05-30-2013 12:44 PM
Quick flash/wireless trigger question loco Flashes, Lighting, and Studio 10 12-15-2011 06:11 PM
All times are GMT -7. The time now is 06:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
