12-02-2013, 11:20 PM   #1
Problem memory cards
I bought it for my K3 two memory cards, Samsung 32GB Ultra High Speed ​​Plus. The camera says "error on the memory card",even after I formatted in the computer
The PC and the Nex 5r read the cards correctly.
Has anyone had the same problem? There is possibility to solve it?
The K3 reads well all the other cards in my possession (no Samsung)
Thank you.
12-02-2013, 11:23 PM   #2
QuoteOriginally posted by Blade Runner Quote
Thank you.
Have you tried formatting the card in camera? The FS needs to be set to exFAT.
12-03-2013, 02:12 AM   #3
Yes, I have tried to format in the camera, but K3 refuses! As soon I get home, I'll try with exFat. Thank you.
12-03-2013, 03:21 AM   #4
I have had several problems with Samsung, TDK and Transcend cards on several different kinds of equipment. My general advice for not getting in trouble is choose SanDisk or Lexar for memory cards.
12-03-2013, 03:30 AM   #5
Na Horuk's Avatar
"Hiccups" with Samsung, Sony, Panasonic... so now I stick with Sandisk
Btw, I remember reading that older cameras (Pre-K-m) could format the SD card and "fix" it for newer cameras
12-03-2013, 03:53 AM   #6
amoringello's Avatar
If you cannot even format the card, chuck it.
But note that formatting is not going to erase the full card. It doesn't hit every bit. Its merely wipes the directory header.
So formatting is not going to give you any idea about the stability of the remaining bits on the card.
Additionally, full disk formatting an SD (like you can do from a computer) is not always the same as formatting a disk. You won't necessarily hit every sector (hardware), event though the format software thinks it has. You need to fill every byte with data, essentially marking it as reserved, until no more bits are available.. (formatting does not do that).
Try a piece of software called "F3". (F3 by Digirati)
You can fill the card with data and read it back to verify it was written correctly.
I do this several times in a row until the final sector count is consistent between multiple runs.
I had a brand new card that had some bad sectors and caused a memory card error.
I ran this a few times and the SD card's firmware marked those sectors as bad.
Its now stable as can be... although a few kilobytes smaller.
Simply attempting to write a large file until the card fills up may cause an error to the OS and fail to write out the last block of data. On an SD, that block may not remain the "last" block forever and if it is bad, you may hit it again at any time.
You need a program that knows the exact amount of data to successfully write out to fill every byte.
Be careful formatting in older cameras. If they don't know about higher capacity cards, they will effectively partition the card into a smaller size that the camera can handle. This can be very difficult to recover from, as the card was not given a partition table by the old camera formatting. So most software won't know that it can be made larger.
FYI;
Just to make card buying decision tougher...
Never had a problem with Transcend. I have dozens of those cards. Some five+ years old.
I bought two Lexar cards (reputable dealer, not eBay counterfeits), and both had so many failures I threw them out in under four months.
So far I have not had problems with Sandisk either... so perhaps they may be more consistently not bad.
12-03-2013, 06:55 AM   #7
Thank you.
i have the same problem with these Samsung cards, they do not work in all the cameras i have, only in certain ones.
12-03-2013, 09:35 AM   #8
No attempt has so far obtained results!
12-03-2013, 09:46 AM   #9
photolady95's Avatar
Location: Cruising PentaxForums and watching your back.
Get rid of the Samsungs and buy SanDisk. Btw, I've used PNY's in my last cameras but for the K-30, I bought a 32gb Sandisk extreme. Mostly just cause I wanted one.
12-03-2013, 11:49 AM   #10
I have two Samsung micro SD cards 32GB and for some reason they are very unreliable in any device I put them except my Samsung TV, Samsung Galaxy Note and my PC (which is not Samsung). Any other device I put them in will work sort of OK as long as they only read but as soon as they write anything the data on the card gets completely corrupted.
I used to use Kingston but twice had problems with my K-r and since then have used only Transcend and never again had any issues.
12-05-2013, 04:51 PM   #11
I took delivery of 2 Sandisk Extreme Pro 32Gb cards (95Mb/s) from B&H.
One of these cards is faulty, refusing to format in the K-3, on a Windows 8 PC, and my workhorse Linux PC. Probing the usb bus on my Linux box, the faulty card is reporting its capacity at 30mb.
At $60 a pop, I am not just going to bin the bad one, so I've initiated a warranty claim with Sandisk.
To date, I've used Sandisk products exclusively without issue, so this is very likely one of those occasional aberrations.
12-05-2013, 07:15 PM   #12
klkitchens's Avatar
PNY, Transcend, Sandisk, Delkin, etc. never had any problems with any of the SD cards I've ever used.
12-05-2013, 09:06 PM   #13
Action Jackson's Avatar
I've used Patriot in CF (8gb), many micro SD (16, 32, 64gb) and SD (16, 32 and 64gb). Not a single problem. Note that flash memory will eventually fail.
12-05-2013, 10:22 PM   #14
I've had 2 Transcend. Both about a year old. One physically disintegrated, the other one just won't take any data anymore, even after a low level format. My 5 year old SanDisk only recently started to give me some problems (contacts used up too much?). After much use. I'm happy with Kingston and SanDisk. Everything else I avoid.
cards, dslr, k-3, k3, memory, pentax k-3, samsung
K5 memory cards sterretje Pentax DSLR Discussion 5 12-02-2013 04:49 PM
memory cards judys Troubleshooting and Beginner Help 6 09-18-2013 04:31 PM
dane memory cards fewing1 Troubleshooting and Beginner Help 4 03-01-2012 07:16 PM
Problem with the memory cards!! Pepe Guitarra Troubleshooting and Beginner Help 12 10-03-2011 08:48 AM
K7 video and Memory cards, or how to fix a 720P problem nakey Video and Pentax HDSLRs 53 09-28-2009 12:12 PM
All times are GMT -7. The time now is 03:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
