Hello all,
The short version: Is anyone here using Capture One 7 to process DNG files from the K-3? If so, what steps do you take to convert the DNG from the camera to a format that C1 understands?
I've taken a couple hundred shots with the K3, but now that I wanted to import them into Capture One for further processing, to my dismay I noticed that all images have the colors all messed up
No amount of adjustment I make within C1 corrects it.
The issue apparently is that C1 doesn't have a ICC profile for the K-3 yet, and none of the other Pentax profiles are able to get close enough either. I was in touch with Phase One tech support about this, but their only answer basically was that they've logged my request, but can't give any sort of estimate as to when a profile for the K-3 will be available within C1 (small company and all). I've tried using Adobe's DNG converter to convert the files from the camera to a version that C1 would understand, but so far haven't found a setting that worked (although running the files through the converter did produce a version that OS X is now able to preview).
Any suggestions?
