03-30-2016, 09:08 PM   #91
Otis Memorial Pentaxian
QuoteOriginally posted by calsan Quote
I got a message back saying they don't do 71x49mm - the one I have is the best matched size for the K3 and do I want to return?
I said I won't return, because postage costs from Australia are too high. Give them their due, they do actually answer emails / ebay messages.
If you can manage to position it exactly with a 1mm gap on the left and right sides, it would look OK.
The one that I got that finally fit is 70x49mm.
04-04-2016, 08:50 AM   #92
jpzk's Avatar
Well !! I sure hope mine will be that size too !
Still waiting for the delivery.
When did you order yours, maybe I will be one to receive the "new" batch! ?
04-04-2016, 09:51 AM   #93
QuoteOriginally posted by jpzk Quote
Summer 2014...
04-06-2016, 06:50 AM   #94
jpzk's Avatar
Summer 2014...
So, I've received the ACMAXX screen protector and it is the same size as yours: 70 x 49 mm.
I just "eyeballed" it (placed it over the screen with the sheath still on) for size over the rear LCD ... it seems a bit small ?
Not sure how much area it is supposed to cover.
I will install later when back from work and see what happens.
JP
04-06-2016, 07:46 AM   #95
JP
The K-3 is problematic in that the LCD is inset rather than flush with the back. The protector is supposed to sit down within the LCD frame. Sideways centering is a little difficult, but once set, should be watertight.
04-06-2016, 09:21 AM   #96
jpzk's Avatar
Thanks Steve.
Advice appreciated !
04-06-2016, 03:36 PM   #97
jpzk's Avatar
So, I installed the screen protector (ACMAXX) and it was apparently the right size but I think I goofed trying to centre it properly as you can see in the picture below ( you have to click on it to see it as a "shared" image).
I hope this will not cause stuff to leak inside and between the screen protector and the LCD itself !!
The smaller top LCD protector seems to be fitting correctly.
https://www.flickr.com/photos/rdlphotos/shares/32sb23
Let me know if the link works.
JP
dslr, k-3, k3, lcd, lcd protector, pentax k-3, post, screen, steve
LCD screen protector for K-01 pony.rojo Pentax K-01 19 12-24-2014 10:39 AM
LCD Screen Protector for K-5 mcook Pentax K-5 17 07-14-2012 11:15 PM
Giotto LCD Protector for K10D BBear Pentax Camera and Field Accessories 9 08-27-2008 04:33 AM
LCD screen protector for K10D heatherslightbox Pentax DSLR Discussion 21 02-16-2008 08:55 PM
LCD Protector for K10D MShawn63 Pentax DSLR Discussion 12 06-20-2007 12:34 PM
All times are GMT -7. The time now is 12:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
