12-06-2013, 07:26 AM   #1
LCD protector for K3
Hi,
Any suggestion on the best option to protect the K3's 3.2 inch display?
Thanks
12-06-2013, 08:14 AM   #2
klkitchens's Avatar
Just ordered this one yesterday. Will be here by Tuesday. I used the same product on my K-5 and it's great. No interference with the screens and is removable if need be. Comes with the protector for the top display too.
ACMAXX 3.2" HARD LCD SCREEN ARMOR PROTECTOR for Pentax K3 K-3 K3D D DSLR
My Review of the ACMAXX (for the K-5) on photographyvoice.com
12-06-2013, 08:16 AM   #3
Thanks! I will get that one them.
12-06-2013, 08:29 AM   #4
What about the bevel?
Will these things fit with the bevel on the right side of the rear screen?
12-06-2013, 08:34 AM   #5
klkitchens's Avatar
QuoteOriginally posted by ENicolas Quote
Will let you know Tuesday
This is designed for the K3 not a generic 3.2" cover, so I assume that's compensated for.
12-06-2013, 10:43 AM   #6
fit with the bevel on the right side of the rear screen-98%
12-06-2013, 11:38 AM   #7
Using ACMAXX for my K-5 and K-01, as well as several past cameras. Highly recommended. Getting one for my new K-3. Hopefully no problems
12-06-2013, 12:17 PM   #8
GIOTTOS AEGIS MULTICOAT SCHOTT LCD SCRN PROTECTOR SP8320 which is available through B&H. It is pricey, but I have piece of mind as well as everything comes through great. Note that at this time it is not specifically for the K-3.
12-09-2013, 06:05 PM   #9
klkitchens's Avatar
QuoteOriginally posted by klkitchens Quote
Just received this today and installed without a hitch.
Some thoughts...
1. It could be a little wider to be honest. Just a smidge. If I look at it from the left side of the camera I can see the view screen under it.
2. It rides on top of the LCD (but is non-damaging and removable). The right side bevel is not a factor.
3. Installation of the main LCD protector and top screen protector are a piece of cake. However, since the main LCD is larger than the protector (though the viewing area is not) make sure you have the camera/screen on so you can place it with the proper margins and not overlap the edge of the viewing area.
Will add some pictures later.
12-09-2013, 07:27 PM   #10
Some thoughts...
I installed my ACMAXX on the K3 too. It's about less than 1.5mm short on left & right and about 1mm from top and bottom.
I contacted the seller because according to the ACMAXX website, the protector shouldn't sit on the LCD.
12-09-2013, 07:40 PM   #11
klkitchens's Avatar
QuoteOriginally posted by Teal Quote
Hopefully then they will replace it.
12-10-2013, 11:38 PM   #12
I received the replacement main LCD protector today. It's slightly larger now compared to the original I received though it's still sitting on the actual LCD and not around it. However, I'm happy with it so case closed for me. The original K3 protector I was able to put onto the Nikon J1 (fit perfectly).
I highly recommend the ACMAXX protectors. I've been using them since my ist*DS and DL, K10D and K5.
12-11-2013, 06:07 AM   #13
klkitchens's Avatar
Did you just go through general customer service?
12-11-2013, 06:33 AM - 2 Likes   #14
krebsy75's Avatar
Putting a screen protector on the K-5II and K-3 defeats the benefits of the gapless display (that is glass). My wife and I fly unprotected.
12-11-2013, 04:22 PM   #15
raider's Avatar
Could you please show some photos how the screen fit to the k3? Thanks
dslr, k-3, k3, lcd, lcd protector, pentax k-3, post, screen, steve
LCD screen protector for K-01 pony.rojo Pentax K-01 19 12-24-2014 10:39 AM
LCD Screen Protector for K-5 mcook Pentax K-5 & K-5 II 17 07-14-2012 11:15 PM
Giotto LCD Protector for K10D BBear Pentax Camera and Field Accessories 9 08-27-2008 04:33 AM
LCD screen protector for K10D heatherslightbox Pentax DSLR Discussion 21 02-16-2008 08:55 PM
LCD Protector for K10D MShawn63 Pentax DSLR Discussion 12 06-20-2007 12:34 PM
All times are GMT -7. The time now is 10:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
