Originally posted by klkitchens Always meant to get the BG4 battery grip for my previous cameras, glad now that I didn't since it wouldn't fit the K-3. But I just got my BG-5 today and it's very nice and gives a good heft. I bought it primarily for the extra battery power though I've rarely run out of juice on a shoot unless I grabbed partially charged ones by mistake. The reaching over the top of the camera for portrait mode never fazed me, but still it will be nice to hold it normally and shoot portraits.
So I've set the camera to use the grip battery first since it's the easiest to change out as needed, but I'm wondering about a few things.
1. the tripod mount is now off-center from the lens. Any issues with this?
2. For tripod mounting, I've seen L-brackets which I assume make it easier to switch between P and L. Is this right and is there one people recommend?
3. If I turn the camera off, but not the grip, will it drain the battery or does it power off as well?
Anything else worth knowing?
Thanks!
I've used grips on every body since at least the K-7. Maybe before then, I can't remember. I'm sure most folks would find the way I use them to be odd in that I almost don't "use" them. I hardly ever use any of the controls nor do I hold the camera by the portrait grip when in portrait mode. I'm just so used to holding the camera "sideways" that it takes a concerted effort to actually use the grip. Weird, I know. But I just find that the camera feels odd to me without it. I use a hand strap exclusively (I hate neck straps) and have it mounted to an arca plate that I have mounted to the bottom of the grip. The grip gives the body more length down the side, making it fit better in my hand, and I don't even have big hands. The extra heft also feels better to me, though I only use a battery in the grip, not the body (hey, another way I don't get full usage of the grip!), so there isn't
that much extra weight.
Anyway, as to your questions;
1. Never been an issue for me, either, though my arca plate somewhat minimizes the off-center issue.
2. RRS
would be the brand to get, except that they don't make one, at least not for the body + grip. I think Kirk may have made one in the past, but not currently. AFAIK no one currently makes one specifically for the K-3 + grip. Hopefully, the K-3 will be a big enough hit that these kinds of issues will begin to go away.
3. Again, since I don't use the controls, I don't worry about the power switch, but I think blackcloudbrew may be right about that.
