12-11-2013, 04:04 AM   #1
Which battery for K-3
Hi Guys,
Can anyone tell me which is the correct battery to fit a K-3? I believe it is a D-LI90 - at least that's what I thought it said on the back of mine when I looked briefly last night.
Wierdly the official Ricoh specs state a D-LI90P - 'Battery Type: Rechargeable Lithium-ion Battery D-LI90P' which I don't believe exists?! must have been a typo!
Cheers
Alex
12-11-2013, 04:23 AM - 1 Like   #2
There is a new safety requirement for some countries that require a 4th battery contact. This only matters for charging, the camera can take either as it only has 2 contacts anyway.
The D-BC90 charger will only charge the D-LI90 battery. The D-BC90P charger will charge the D-LI90 and D-LI90P batteries.
12-11-2013, 04:26 AM   #3
Arne Bo's Avatar
Hi, in the user manual (the german one) the D-LI90 is listed and is working fine for me. Havenīt seen a D-LI90P at the store.
12-11-2013, 05:25 AM   #4
IMO, just get the grip + AA's and forget about battery life.
For a price of one 3rd party Li-ion battery you can get 6 decent AA's that will last at least two time more. Also, having spare AA's are always handy, because you can use them in your flashes or just everyday devices, if needed
Also, the new AA's are much better in cold weather than they used to be, so again, one more reason to use them instead of Li-ions.
My Li-ion (that came with camera) is in a battery tray, deep in camera bag, waiting for emergency
12-11-2013, 06:21 AM   #5
i83N's Avatar
If I not mistaken LI090P where LI means Lithium and P means polymer.
12-11-2013, 06:22 AM   #6
i83N's Avatar
QuoteOriginally posted by Apapukas Quote
If you go AA root just get eneloops
12-11-2013, 07:49 AM   #7
The one thing I will mention is that I have some off brand batteries that work for my K5, but not for the K3. They don't hold a charge very well any more, but in the K5 they are good for 200 or 250 shots. They are useless in the K3 -- I guess the voltage isn't high enough, because they will shoot a couple of frames and then give battery depleted message.
12-11-2013, 07:59 AM - 1 Like   #8
grhazelton's Avatar
Interesting. I've had good performance from "Wasabi" brand Li batteries in both my K 10 and K 5. Of course this doesn't speak to the K 3 and as always YMMV.
12-11-2013, 08:14 AM   #9
Thanks - I've got the grip and currently use AA's with it but was thinking about getting a spare Li-ion battery so while on the road I can use either the AA's or the Li-ion and just switch the tray in the grip.
What AA's would you recommend? I have some eneloop XX ones currently but they seem to be causing problems with my K-3 when in the grip - I am getting the mirror flop/shutter issue (see the thread).
Cheers
12-11-2013, 08:17 AM - 1 Like   #10
QuoteOriginally posted by grhazelton Quote
Yes, the Wasabi batteries are what I have and they do work fine in my K5, but it is just that in the K3 it shows battery depleted really fast and then starts flipping the shutter really fast. Has never happened with the factory batteries.
12-11-2013, 08:43 AM   #11
QuoteOriginally posted by sharepointalex Quote
Cheers
On my K5IIs I use the standard eneloops ~2000mAh. The only issue that bothers me a little, is that sometimes when I press the preview button, the picture appears on the LCD for a second and then the LCD goes black. I have to keep pressing the preview button for up to 5 times to finally view my pictures normally! It annoys a little, but because it happens quite rarely, I don't mind too much.
I believe that your problem is related to the camera, not the AA's. Just wait for a couple firmware updates on "general stability" or "general stability using AA's"
Also, to use your AA's to the fullest, you need a good charger. I highly recommend BC- 700 charger. Also, it allows you to see how much mAh your AA's actually have.
12-11-2013, 10:00 AM   #12
narual's Avatar
Hah, and you can strap some wrist weights on while you're taking pictures, too! You must have strong forearms.
I carry the insert with AAs in my camera bag for emergencies, but that's more weight than I want to carry inside the camera if I can avoid it (plus you lose the weather-safe spare SD card storage).
I picked up 2 cheap 3rd party batteries on Amazon, plus the original with the camera. With 1 in the body and 1 in the grip, I've never run out (though I came close a few nights ago because I had forgotten to charge them after the last two times I went out taking photos), and if I did, I still have the third before I have to use the AA grip insert.
Of course, this is for my K5, and maybe the K3 doesn't handle third party batteries well?
12-11-2013, 10:13 AM   #13
QuoteOriginally posted by narual Quote
Well, I shoot with DA Ltd's so even with the AA's the camera weight is very good
P.S. Thank you, I do try to stay in good shape
12-11-2013, 10:17 AM   #14
narual's Avatar
For AAs, if the NiMh 1.2 voltage is too low, you could try NiZn batteries. They put out 1.6 volts. They don't have the kind of shelf life or recharge cycle life that Eneloops have though, and they require a special charger.
Normal alkaline batteries use 1.5 volts, so perhaps the k3 expects 1.5 volts if you're using the battery grip, and 1.2 volts isn't enough.
Disclaimer: they may not last long, could fry the camera, and may summon the hordes of Genghis Khan to torch your home village. I've never personally used them, so I have no idea.
12-11-2013, 10:32 AM   #15
I'm no electrician, but based on simple math, 1.2 should be enough.
Pentax Li-ion battery has voltage of 7.2V
Standart eneloop - 1.2V. 6*1.2=7.2V
So, if you used 1.5V batteries, the voltage would rise to 9V. That is 25% higher voltage than using Li-ion or 1.2V batteries.
I believe there is a pretty high chance to fry the camera this way.
battery, d-li90p, dslr, k-3, k3, pentax k-3
Pentax K-5 D-BG4 Battery Grip on a K-3, really possible? pentaxmz Pentax K-3 8 12-02-2013 05:55 PM
For Sale - Sold: Pentax D-BG4 Battery Grip for Pentax K-7 & K-5 with Battery djrocks66 Sold Items 4 08-11-2013 08:10 AM
3 Pics, 3 Lenses....Can you tell which is which? Driline Pentax SLR Lens Discussion 19 06-21-2013 08:13 PM
For Sale - Sold: Pentax D-BG4 Battery Grip for K-5 / K-7 w/D-Li90 battery Adam Sold Items 3 05-31-2013 01:05 PM
Which battery? (K-x) emsuraine Troubleshooting and Beginner Help 16 03-02-2011 11:44 PM
All times are GMT -7. The time now is 03:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
