12-19-2013, 06:04 PM   #1
klkitchens's Avatar
Score "1" for Pentax PEF... I guess...
Downloaded the latest version DxO Optics Pro to play around with the lens corrections abilities...
Was thrilled to see that it already had profiles for the K-3 (yay!), however when I navigated to a folder chock full of K-3 DNG RAW files, it said there were no files in the directory.
I sent a query to DxO about this and lo and behold got this reply:
Hello Kevin,
Thank you for your request.
We are experiencing some issues with the support of the DNG files from the K-3.
Our developers are working on it and a solution will be provided by January 15th.
We apologise for any delay. In the meantime, please use the PEF files.
So there's one reason to keep using PEF, if you're using Optics Pro...
12-19-2013, 06:28 PM   #2
Kevin, I use DXO and Google-NIK software. I discovered the same with the DXO Optics Pro v9 software also. I sent them a note also and notices their website indicated the Jan, 2014 timeframe last week. Can't wait as I like the software since is camera-lens specific in corrections. I also notices that Photoshop CS6 appears to still have problems with the K-3 DNG files and if you use lens correction in Photoshop, the K-3 is not listed still although you can see the EXIF info shows K-3. I do have the camera raw update that includes the K-3.
12-19-2013, 07:21 PM   #3
lm4187's Avatar
I've run into the same problems with DxO9 and have found a couple of non-ideal work arounds.
It turns out that DxO9 can open and process K-3 TIFF files. You can use DCU5 to bulk convert DNG to 16-bit TIFF and then run DxO9 for lens and other corrections. The downside is that DCU5 doesn't seem to support compression. The resulting .tif is around 141MB. Additionally, the conversion is very slow. I converted several hundred DNGs to TIFF by this method, applied DxO9 processing to get the jpgs I wanted. Then I deleted the TIFFs. The processed jpgs seemed to be comparable to the results I get with K-5 DNGs processed directly.
When DxOlabs fixes their DNG problem it will be interesting to compare DNG->TIFF->DxOjpg with DNG->DxOjpg.
I also found that Fast Stone Image Viewer converts DNG to TIFF, but the resulting TIFF differs compared to the DCU5 TIFF conversion. More investigation is needed.
Other software packages might work as well, or better, for this purpose.
[Incidently, Kudos to DxOlabs for getting the PEF (and TIFF) working for the K-3 so soon. I was afraid I was going to have to wait until January.]
Cheers,
Lou
12-19-2013, 09:33 PM   #4
QuoteOriginally posted by lm4187 Quote
You can also do this in camera, from the Playback mode menu - even whole folders full of images
The K-3 DNG issue DxO report is interesting. The K-3 DNG's seem quite quirky, judging by the issues various RAW tools have been having with them.
12-19-2013, 09:59 PM   #5
I just looked at the Playback menu - it shows "Slideshow", "Quick Zoom", "Highlight Alert", "Auto Image Rotation", "Protect All Images", and "Delete All Images" - not a thing about conversion to TIFF.
12-19-2013, 10:04 PM   #6
QuoteOriginally posted by ENicolas Quote
Ah - I see - not "Menu" but the "Options" when you are viewing an image: one of the options is to convert raw to JPEG or TIFF! Excellent!
12-20-2013, 12:59 AM   #7
I just tried the latest version of DXO 9 and it opened the K3 DNG files and manipulated them perfectly.
David
12-20-2013, 01:41 AM   #8
Pablom's Avatar
I thought there is no PEF any more on new Pentax bodies
12-20-2013, 02:23 AM   #9
My K3 can do either PEF or DNG.
12-20-2013, 03:13 AM   #10
Banned
You Always turn them incamera into TIFF-files if you can't handle DNG nor PEF
12-20-2013, 05:41 AM   #11
Mikesul's Avatar
This is really interesting. I suspect most of us have been using DNG for a while since that format is supposed to be more universal (earlier support of new cameras they said) and, of course, because some recent Pentax cameras no longer supported PEF. Now the K3 reintroduces PEF and it appears that at least some raw processors have difficulty handling K3 DNGs. DX0 has managed to handle PEFs but not DNGs. So does this mean that we should all us PEF for awhile to improve compatibility? Is there information in the new K3 which just does not fit well in DNG? How can that be since both formats are supposed to only be container files which contain the same date? I am sure there is a simple explanation but I do find it interesting. I will try PEF this weekend with DX0 to see what I get.
12-20-2013, 06:24 AM   #12
klkitchens's Avatar
As DxO is not part of my normal workflow (yet) but DNG is,I will wait until mid January to explore the benefits of DxO with the K-3.
12-20-2013, 06:45 AM   #13
QuoteOriginally posted by David&karen Quote
That would be good. But which version are you using?
I have DxO Optics Pro v9.0.1.1469 installed and it can't read K-3 PEF or DNG's.
And the version they offer under the DxO 'Check for updates' menu (v9.1.1563) only offers ' K-3 support - PEF'.
If they stepped up the pace and delivered their January update with K-3 DNG support early, that would be welcome.
12-20-2013, 07:10 AM   #14
whatever is the current update version is the one I used and I dl'ed this morning.
David
12-20-2013, 07:32 AM   #15
Ok, I have DXO 9.1.1 build 39 64 bit for MAC. Hope this helps.
David
dng, dslr, dxo, files, k-3, k3, optics, optics pro v9, pef, pentax k-3, raw
new Sigma 30/1.4 "Art" not available for Pentax kevwil Pentax SLR Lens Discussion 53 02-14-2014 05:48 AM
Optical differences between Pentax "K", "M", and "A" lenses 6BQ5 Pentax SLR Lens Discussion 31 01-10-2014 01:02 PM
ME super: can I use "M" lens in "auto" setting. treetoile Troubleshooting and Beginner Help 4 03-25-2013 10:03 AM
Beauty Shoot for "Citizen K" Magazine "How Did I Do It?" benjikan Photographic Technique 25 12-05-2009 05:33 AM
Pentax "A" lens and "F" 1.7X converter on K10d yyyzzz Pentax SLR Lens Discussion 4 07-09-2009 05:04 AM
All times are GMT -7. The time now is 03:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
